Old 09-11-2012, 01:05 PM   #1
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Default Re: Quadrajet Gasket and tuning
Originally Posted by mat H/SA View Post
Hello,
Im running a 350/255 combo in G/SA
I would like to know what carb gasket people use,
I currently run a open style one and want to know witch one is the best
Also, i start the run really rich and in 2nd and 3rd gear it leans a bit too much, how can i fix this
Thanks
Call and make a purchase from Danny Ashley !!
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 09-11-2012, 01:27 PM   #2
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
Im running a Danny Ashley
I run 7psi, but cant see it while a do my run, will try to install my gage elsewhere.
mat H/SA is offline   Reply With Quote
Old 09-11-2012, 02:00 PM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Quadrajet Gasket and tuning
Mat,
What kind of fuel pump do you run ? Yes, you need to see the fuel pressure gauge while you are making the run ... I think you will be surprised when you put the gauge on the cowl outside near windshield ... Then you can see what's happening in 2nd & thru traps ..
Sounds like lack of fuel , check it out ... Hope you are doing well ..
Give Danny a call he will help you out .................
Dave Ribeiro 1033 STK
Old 09-11-2012, 02:53 PM   #4
mat H/SA
mat H/SA's Avatar
Hi Dave its been a while! i am well thanks
I run a barry grant 280 fuel pump.
and what about the gasket, is a open better than a 4 holes?
Old 09-11-2012, 03:43 PM   #5
Reed Granrt
Hey Mat
Are you using a datalogger. If you are not, this is a good time to get one. That way you can monitor more than one thing and at that time install an O2 so you really know what is happening (And ya aint gotta watch fur it). Just a suggestion. Also install a couple of egt's so you know what else is a happening.
reed
Reed Granrt is offline   Reply With Quote
Old 09-11-2012, 03:47 PM   #6
FED 387
Liked 333 Times in 180 Posts
FIRST get rid of the BG pump--second buy an Aeromotive pump like a 11203 uses less AMPs, Magna Fuel or a Weldon both great pumps too-- stay away from the Holleys too---check ALL your hose sizes make sure they are adequate for your set up place fuel pressure gauge so you can monitor whats going on during the run--then if problem persists call D.A.
Old 09-11-2012, 07:11 PM   #7
Dean Oliver
Mat,
As gsa612 said, you are allowed to run two gaskets under a stocker carb. Most Q-jet engines, including mine, prefer two of the 1/4" thick open gaskets. Applications that have a low rpm range will typically like two of the four hole gaskets. Some racers do run a combination of the two on a SBC, and as cheap as gaskets are you should try every possible combination. You'll find one combination that will be worth at least .02-.03 over the others, so it could be the cheapest hp you'll find.
As for your rich/lean issue, are you basing this on O2 data? As long as your fuel system is adequate, you can lean a Q-jet on the front end and richen it on the top end (or vice versa, or do one of the two independently).
Dean
Dean Oliver is offline   Reply With Quote
Old 09-11-2012, 07:44 PM   #8
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Ahh... Now you have THE MAN involved ! ^^^^
What size lines do you have and what reg are you using ? You should call Deano. Danny has great stuff too.
2894 STK
Old 09-11-2012, 07:51 PM   #9
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Assuming the fuel delivery checks out, the high-speed bypass tubes can be drilled out to richen the top end only. Danny Ashley may have already done this for you, but you should ask if it was done, and if so, to what size.
After making this change, you may need to use leaner secondary metering rods.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
