Old 07-31-2012, 05:02 PM   #1
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Re: carb help, Holley dbl pump.
keith, that hole in the venturi hsg. is for holleys timed port vac. system, not in new hsg's such as the 950's. if this application is for a race car "plug" it with some jb weld or a small brass plug, you don't need it. wish i had seen the pic's before as i thought you were using stock metering blocks......good luck.....
NORMAN BARNARD is offline   Reply With Quote
Old 07-31-2012, 05:34 PM   #2
Keith 944
Keith 944's Avatar
Originally Posted by NORMAN BARNARD View Post
Keith, that hole in the venturi hsg. is for holleys timed port vac. system, not in new hsg's such as the 950's. if this application is for a race car "plug" it with some jb weld or a small brass plug, you don't need it. wish i had seen the pic's before as i thought you were using stock metering blocks......good luck.....
you helped me a great deal, thank you. this is a street/strip car. the hard start thing was driving me batty! i knew we would get it worked out eventually. again to everyone that made any input, I THANK YOU !!!!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-07-2012, 11:08 AM   #3
66Cuda
I have a quick fuel metering block 34-4 on my carb.....Same darn thing has been happening.... I have had the carb apart 6 times trying to figure this out....It leaks out of the passenger side front transfer slot....Floods the motor and ruins the oil.....I was going to try my old metering block today....but maybe I can just plug the hole...
66Cuda is offline   Reply With Quote
Old 11-07-2012, 07:15 PM   #4
Keith 944
Keith 944's Avatar
yep, i plugged the hole and flipped the gasket just in case. been working great ever since!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-08-2012, 11:19 PM   #5
66Cuda
You can just flip the gasket? I have a few gaskets I'm looking at right now....If I flip one onto the other...three holes are different...I'm gonna go grab a metering block and look at it....I put my stock metering block back on and the leak stopped. Maybe it's in my head but the car doesn't feel as fast....I'm going to the track Saturday.
Old 11-09-2012, 05:58 PM   #6
Keith 944
Keith 944's Avatar
yeah, i flipped the gasket, it was a quick fuel gasket, had to poke a new hole for one alignment peg, all other holes stayed same except one at bottom, and i did plug that hole anyway....
if you just want to try it out, i put aluminum tape over that hole on the main body first. that is when the leak stopped.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
