Old 11-07-2012, 07:15 PM   #1
Keith 944
Keith 944's Avatar
Default Re: carb help, Holley dbl pump.
yep, i plugged the hole and flipped the gasket just in case. been working great ever since!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-08-2012, 11:19 PM   #2
66Cuda
You can just flip the gasket? I have a few gaskets I'm looking at right now....If I flip one onto the other...three holes are different...I'm gonna go grab a metering block and look at it....I put my stock metering block back on and the leak stopped. Maybe it's in my head but the car doesn't feel as fast....I'm going to the track Saturday.
66Cuda is offline   Reply With Quote
Old 11-09-2012, 05:58 PM   #3
Keith 944
Keith 944's Avatar
yeah, i flipped the gasket, it was a quick fuel gasket, had to poke a new hole for one alignment peg, all other holes stayed same except one at bottom, and i did plug that hole anyway....
if you just want to try it out, i put aluminum tape over that hole on the main body first. that is when the leak stopped.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
