Liked 2 Times in 2 Posts
On a powerglide, which fluid outlet, top or bottom, would go into a filter\transcooler ? The filter has a in and out on it. Thanks
Bottom out, top in
Denny |
But, can both be plugged?
I know this can't be done with a T350, as there must be a loop connecting the two ports to keep the path of fluid open. However, I've aquired a race prepared powerglide and both ports are plugged. Is this OK?
Bobby & Norene Zlatkin L/SA |
#4 | |
Remove the bypass ball and spring assy., plug the holes, and you will loop the fluid internally.
