Old 06-19-2012, 05:29 PM   #11
Billy Nees
Default Re: Pure Stock-1995 Olds Achieva
400 lbs. in that car is probably more than a second! P/S is probably 2-3 tenths. you can remove the exhaust fron the manifold back.if you use stock manifold.
Billy Nees 1188 STK, SS
Old 06-19-2012, 05:47 PM   #12
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
As I was telling Robert Sunday at the track, the thing hasn't had a set of plugs in it in who knows how long, the stock air intake is still on it and looks VERY restrictive to me. Full exhaust... Cheap gas... there ae a lot of little things that can be done.
I believe there is an idler to replace the A/C Compressor as well.
By the way, Bob did a darn fine job of driving considering it's been thirty years since he has done it. No tach or temp guage and we had passes with in .03 of each other and he ran .007 off his dial in... The kid that beat him dropped a nice package on him.
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 06-20-2012, 05:51 PM   #13
SBDART
SBDART's Avatar
I see a road trip to muince one saturday Bob.. and run it in the 1/4 mile. just to see what she can do. pick me up on the way up and i will go for sure. LOL
SBDART is offline   Reply With Quote
Old 06-20-2012, 09:37 PM   #14
I may be fairly ignorant about IHRA, but why a FWD car in Pure Stock?
What's the problem with, say CF/SA?
BTW, is this a Quad 4 or it's descendant ?
Old 06-20-2012, 10:13 PM   #15
Tod Lane
Tod Lane's Avatar
Road trip....
He owes us one since we didn't go to Georgia after the trailer that time...
Tod Lane
Old 06-20-2012, 10:21 PM   #16
Robert Swartz
Robert Swartz's Avatar
Interesting. 1/8 index is same as I/PS, 1/4 mile index is 15.15? Frankly, was looking at this purely from the sense of not having a great amount of money thrown into it. Weight wise it's already close. Making it a full fledged NHRA car does open up many possibilities.
Yes, it's one of the 16 valve Quad 4's. I haven't done my homework yet, I guess there are more than a few versions of these motors.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 06-21-2012, 08:40 AM   #17
Dennis Banach
Robert,
I just took a look at the guide engine is rated at 150 hp, the 155 is a V-6.
Was the 2900lb.s just the car ? If so it would fit in EF/SA for IHRA 1/4 index is 15.90 1/8 9.85 car would need to weigh 2850 + plus 170 = 3020. IHRA break for E is 19.00 lb.s It would be DF/S in NHRA 1/4 index 15.60 1/8 9.71
I had a friend with a Grand Am it was a `97 Quad 4 he used to run low 16s with it with some short street tires, a chip or something for the computer and not much else. It was about 10 yr.s ago so I can`t remember for sure all what he did but I know it was not much. It was his wife`s DD .
I would think you should be able to hit the index with very little money.
Best of Luck !
Dennis Banach is offline   Reply With Quote
Old 06-21-2012, 09:07 AM   #18
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
I don't think front wheel drives are in pure stock anymore there used to be front wheel drive pure stock classes but they are gone and don't think they go in to regular pure stock.
I remember Ray Head and some others running rental cars in front wheel pure stock years ago.
Mike Taylor3601
Mike Taylor 3601 is online now   Reply With Quote
Old 06-21-2012, 02:39 PM   #19
Robert Swartz
Originally Posted by Dennis Banach View Post
Robert,
Best of Luck !
Well, after your post, I went back to the guide. Seems seems my reading comprehension and research skills are lacking. I completely misread the guide. Even if FWD cars can run in Pure stock. At 150 hp, it doesn't fit. I saw the DOHC and made an assumption. We all know how that works out.
So, at 17.46, it factors out as a natural BF/S car. So, we're now staring at Mark Yacavone's suggestion of running the car as a CF/S at 17.50. Really the only logical class choice. Good news is, it makes the weight issue come into line with where the car is at. With the car weighing 2900, in CF/S it can weigh 2795. I'm looking at losing at least 300lbs, figuring I first have to lose a couple hundred pounds to compensate for my own weight, you're looking at losing an additional hundred pounds to bring the car to weight.
Where this really changes the game. In CF/S, this car falls into the realm of the traditional stocker. That puts this whole idea into a different cost level. That was the appeal of Pure Stock.
Old 06-21-2012, 04:17 PM   #20
First of all you are looking at the NHRA breaks...
I mentioned CF/SA which is an IHRA class
In IHRA, it's a natural C car.
Now from now on it's a CL or SL model ..Nobody looks at what kind of seat covers you have. It it make you feel better, go to the boneyard and pop off a couple of emblems and glue them on.
That makes it a nat. D car so you go to E @ your current weight (15.90 index)
Doesn't that sound better ?
Most of the weight you remove would have to come of the front end...Not a good idea.
You need a real header and collector (call Billy),
Stocker cams and valve job,
A set of chain gears for the trans (Owen Quirrion)
Minimum 8" or 7" converter (call ME)
Some way to tune the computer (Ed Wright)
It ought to run under the index with a healthy short block.
If you're serious, there's a guy here that can help you (SS3011)
Now grab yourself a Rockstar and get to work !
