#11 |
Liked 165 Times in 59 Posts
i have to ask ,,what lenght shifter (long has a short and long version)and what lenght fork arms are you guys running ???i am thinking the both long shifter and fork arms are creating to much leverage for the ecentric to handle ,,also double checked the adjustment
and mentioned previously the fork slides work perfect as well as the sliding 3-4 dog ring thanks for your replys ,, still investigating gmonde |
#12 | |
#13 |
Liked 29 Times in 5 Posts
I would call jerico and talk to Scott. He has helped me figure out problems more than once.
SS/AM 2917 |
#14 | |
Liked 293 Times in 65 Posts
#15 | |
Liked 1,111 Times in 304 Posts
#16 |
Liked 54 Times in 27 Posts
I run the Mr. Gasket vertical gate, aka Hurst V Gate 2. It has a bolt-on set of stops. For the price, the Long darn sure ought to have stops. Apparently it does:
Designed exclusively for G-Force G-101 clutchless transmission. Allows transmission to be rotated 90ยก for increased ground clearance. Supplied with stainless steel tube rods and Heim-end linkage for all applications. Push-pull design virtually eliminates missed shifts. External shift stops prevent overshifting which can result in transmission damage. http://longshifters.com/shifter_4_vj1000.asp Last edited by Run to Rund; 06-19-2012 at 07:37 PM. |
#17 |
Liked 3 Times in 1 Post
#18 |
Liked 370 Times in 101 Posts
Is anybody doing the burnout in 3rd gear?
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#19 |
Jerico says not to burnout in 3rd; it is the weakest gear due to being against the split between mainshaft and input gear.
#20 |
Liked 165 Times in 54 Posts
thats funny, just about every stickshift i know does them in 3rd....
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
