#11 |
I ordered four when I bought mine. Even if you had to buy 10 you could probably sell the extrs here,lol
2009 V/SA Record Holder |
#12 |
Liked 229 Times in 75 Posts
Robert pm me I have had the same problem with min of 10 to order. I need a couple of switches also.
#13 |
Liked 2,490 Times in 700 Posts
I could use a couple or three myself.
#14 |
A good parts guy can find one..... they are preety comment..... I think they are used a lot in tow motors......... I pay about $10 CDN to prob 15 now for one.......
#15 |
Liked 49 Times in 15 Posts
Why does this switch need to be adjustable?
If you are using an adjustable switch, must you install a brake pressure guage?
Dean Feiock -- Stock 5002 |
#16 |
Liked 534 Times in 143 Posts
Adjustable helps you adjust your reaction time. There is a point of diminishing return. I don't use a pressure gauge, but I always check it for muscle memory right before I pre-stage.
#17 |
OK, then let me ask this.
Is it required that the pressure switch be installed before the line lock on the front brakes? It would seem to me that installation after the line lock would circumvent the "two step applied by brake" rule. If you install it after the line lock, all you would need to do is step on the brake, apply the line lock, and the line lock pressure would hold the front brakes and the two step pressure switch closed. And we all know the line lock switch can be mounted any place you desire.
#18 |
Liked 6 Times in 3 Posts
i have found a very good quality pressure switch through my hydraulic company. it is adjustable and has both n/o and n/c polls, and is setup with a hershman type connector. It has a 1/4 npt nipple. not for the faint hearted if you think its gonna be cheap tho! it runs right around $60 each. i plan on using mine for nothing other than connecting a ground to a red warning light that tells me i have my pedal down to the same location each time in my foot brake stocker. i run a button on my pedal for the two step. i have bursted a brake line at the starting line once and was able to win the round cause the car didnt launch till i wanted it to (the other guy went red behind me!). with a pressure switch in the system opperating the two step the car would have taken off as soon as the pressure dropped.
just my two sense! Ian |
#19 | |
Liked 20 Times in 12 Posts
#20 | |
No special switch, no concern over installing in front or rear hydraulics, no concern over front to rear bias, and no pressure guage. Just step on the brake and simultaneously activate the switch.
