Old 05-11-2012, 06:27 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: afco spring sliders
Mike,
What do you perceive as the problem? I'm considering them on my car.
Jeff Lee 7494 D/S '70 AMX
Old 05-12-2012, 11:13 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
Jeff
The side brackets with the slots that the springs were supposed to slide in were made from thin mild steel. The bolt through the spring was a 1/2 inch bolt with a thin wall mild steel sleeve that was supposed to roll on the bolt. The sleeve wore a groove in the slot and the slot wore a groove in the sleeve. So it actually was in a bind. I think the ones I had were either moroso or SRD. I guess if you made your own with a thicker bracket with the slot and made the slot wider where you could use an actual roller bearing it would be a good system. Maybe make the side bracket from some 1/2 inch aluminum plate with the slot milled in to match the diameter of a roller bearing. Then you would have something.
Mike Pearson 2485 SS
Old 05-12-2012, 11:55 AM   #3
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
We stock and sell a lot of them.
Many go out with Cal-Trac system orders.
I love the way they work and even have them on my own car. Same AFCO's since 1998. See pics.
They do need to be lubricated 3-4 times a year.
We also stock some really cool billet aluminum shackles for racers who do not want to go through the extra work.
Name:	Roller shackle 001.jpg
ID:	11570   Click image for larger version
Name:	Roller shackle 002.jpg
ID:	11571   Click image for larger version
Name:	Roller shackle 003.jpg
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
