Old 05-09-2012, 10:15 AM   #1
henrys57wagon
henrys57wagon's Avatar
Default Re: Longer ball joint.......
In the 80's I made a 1"(I think or 1-1/2) aluminum upper ball joint spacer to raise the upper A arm
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 05-10-2012, 08:01 AM   #2
tj310
Putting a spacer between the upper ball joint and control arm dosen't really do anything other than allow the suspension to droop more. A longer ball joint stud may actually change the arc of the upper arm. ---Trevor
Old 05-10-2012, 08:21 AM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
bingo we have a winner.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 05-10-2012, 12:09 PM   #4
Liked 5,147 Times in 1,964 Posts
Hasn't been legal in Stock since the Junior Stock days.
The longer stud ball joints seem to fall into the "manufacturer's tolerance" category with NHRA..
Old 05-10-2012, 02:26 PM   #5
henrys57wagon
Do you mean by droop that the front end sits lower than without the spacers?
Like many things that are not legal, it is only illegal when you are caught.
Old 05-10-2012, 04:21 PM   #6
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I was under the belief that the long upper ball joint helps put more positive camber in the front end so the front tires are not running on the inside edge possibly scrubbing also.
Might help w more positive caster, but that I'm not so sure of.
chris ok is offline   Reply With Quote
Old 05-11-2012, 09:18 AM   #7
tj310
Droop is the amount the front suspension will hang down in a wheelie situation. The longer ball joints help maintain your camber in droop. The balljoint extenders alluded to were easy to spot poorly manufactued and frequently broke , simple to outlaw.---Trevor
Old 05-11-2012, 10:42 AM   #8
henrys57wagon
tj I agree that the piss pour quality of some of the cast spacers is the reason they outlawed them. My pieces were made from solid 6061 aluminum and were used for 10 years and still good when removed. They are still sold and guys building gasser style cars use them.
Sorry I should have said thanks for the info on droop'd front end. Henry
