Old 05-04-2012, 09:39 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Hoosier Radial Tire Swap?
Jim. I've been running Hoosier Radial slicks since 2000. 30" x 10.5" on my former Chevelle through the 2008 and 32" x 13.5" since then on my Firebird. Swapped side to side after every race for the 2000 season and haven't since then. My 60 foots vary thousanths from pass to pass whether I swapped or not and tire life was the same.
Old 05-04-2012, 10:57 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Talking Re: Hoosier Radial Tire Swap?
Jim, like 1320 said, I to have tried it both ways with the hoosiers. I have found no difference in performance or lasting ability. I typically rotate side to side about every 2nd oil change just part of maintenance. Hope this helps some.
Robert
Robert Simpson is offline   Reply With Quote
Old 05-04-2012, 11:11 AM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
FREQUENTLY ASKED
DRAG RACING QUESTIONS
5. Can I swap tires from side to side? (from left to right and right to left)
ANSWER: Hoosier does suggest, depending on the number of runs, swapping tires on a regular basis. The main reason for swapping tires is to help smooth out or even the tread wear. By swapping tires, it causes the tire to be run backwards, thus causing the tire to wear differently, which cleans up the tire tread. Watch for improper wear patterns on the tread, such as rolling or feathering. The tread surface should have a fine grain or velvet look to the surface. (Top)
I know you stated Radials...but for those with bias....
I swap during the season if I see the tread feathering. 243 passes on last year's set and half tread life left. 29x9 bias.
Clark Doukas
Old 05-04-2012, 11:37 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Hoosier Radial Tire Swap?
I do it after every weekend of racing and check my brake shoes & adjustment while I'm at it. - grasshopper!
Old 05-04-2012, 12:10 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
Hi Jim,
I run a different class and a bigger radial. I dont swap. The tire I use does not feather up. As long as the track is good the tires hook good.
Mike Pearson 2485 SS
Old 05-04-2012, 01:30 PM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thank you oh wise one!Jim
Old 05-04-2012, 01:37 PM   #7
Jim Wahl
Jim Wahl's Avatar
Wink Re: Hoosier Radial Tire Swap?
Originally Posted by cad View Post
FREQUENTLY ASKED
Clark Doukas
Thanks Clark, I guess I should have checked their website first! Jim
Old 05-04-2012, 02:54 PM   #8
1320racer
1320racer's Avatar
No love for Robert or myself, what's that all about?
Old 05-05-2012, 08:41 PM   #9
Jim Wahl
Jim Wahl's Avatar
I got lottsa love for everybody! Jim
Old 05-06-2012, 06:56 AM   #10
Woodro Josey
Liked 3 Times in 1 Post
Jim, yes, you are doing the right thing!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
