Old 05-03-2012, 01:30 AM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Recommended Engine Oil ?
I'm in the process of getting my old beater ready for Mission later this month. Need to change oil. Been using a zinc fortified 30W ( no longer available ), but I know I don't need that much viscosity in an engine thst doesn't see extended driving, or high temperatures. Even fully warmed up, oil presure at 1200-1300 RPM idle, is 25-30... and goes 70+ over 2500. With the engine cool... like tring to make a fast qualifying pass, my oil pressure at RPM, goes scary high... over 80.
Don't like that.
So, do you guys have a recomendation for oil brand / type, viscosity ?
I have an unusual oil pan on my car. It's actually an over-the-counter GM replacement pan, which has an extra 2 quart capacity ( I run 7 quarts in the 8 quart system ). So, I don't have to worry about running the pan dry.
Just trying to make a few good passes there at sea level !
Hey, bringing a spare rear end pumpkin too !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
