Old 04-16-2012, 11:51 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: new slicks
You didn't mention weight in the trunk. Most stickers have considerable weight back there; high and way back. That helps considerably with consistancy and even ET. I'd suggest you get it to work on a set of bias slicks first. Once your there, it will only get better with radials.
Don't forget 9" wide wheels are also an option.
Jeff Lee 7494 D/S '70 AMX
Old 04-17-2012, 08:33 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Most stockers carry weight for the purpose of running a class other than the car's natural class.
That said, this car ain't a stocker yet, rather a bracket car and you'd have a hard time convincing most bracket racers that they need to add weight to hook.
While it will work, it's not need IF the chassis/suspension is setup correctly evident by my Chevelle which carried no additional weight/ballast, who's front to rear bias is 59%/41% of it's 3880lbs., runs on Hoosier radial slicks and will hook in a car wash.
Old 04-17-2012, 03:18 PM   #3
Steve Hayward
Front shocks and bushings are where you should be paying your attention to.........
Steve Hayward is offline   Reply With Quote
Old 04-17-2012, 05:40 PM   #4
Phillip marvetz
Phillip marvetz's Avatar
The radials wear out much faster than bias. Some stocker drivers only run the radials when needed.
2009 V/SA Record Holder
Old 04-17-2012, 05:50 PM   #5
1320racer
1320racer's Avatar
Ran Hoosier's 30 x 10.5 radial slicks on my nearly 2 ton Chevelle that 60 footed low 1.30's and a best of 1.28, for 8 seasons, going through at least 3 sets a season.
Logged a minimum of 75 passes on each set before swapping them out for a new set without any indication the tire was going away with the 60 foots varying thousanths from pass to pass on any given day. Then these same tires went on a lighter weight car and saw another 75 passes minimum before they were retired.
Old 04-17-2012, 05:55 PM   #6
Jeff Lee
Jeff Lee's Avatar
THAT SAID...He asked for advice.
THAT SAID...He said he would like to move towards the car being in Stock Eliminator
THAT SAID...I offered friendly advice along the lines of his question.
THAT SAID...I have more experience than you do in the Class.
THAT SAID...Your Chevelle has an entirely different suspension than the Firebird in question and was not a even a Class car as the OP was asking about.
THAT SAID...He didn't ask about your OLD Chevelle. I'll bet he already knows about it!
THAT SAID...We get it. You don't!
THAT SAID...Go back to the mirror and repeat..."I'm wonderful, I'm special, and by-goly. I want the world to know"
Old 04-17-2012, 06:16 PM   #7
Todd Boyer
Liked 6 Times in 5 Posts
THAT SAID, I think I would run the car at class legal weight now and start dialing in as such. It seems that is what the gent with the Firebird is working toward. I know that's what I'd do.
Old 04-18-2012, 10:40 AM   #8
1320racer
1320racer's Avatar
Old 04-18-2012, 12:40 PM   #9
copperhead
Liked 11 Times in 8 Posts
Where is the "Like" button?
copperhead is offline   Reply With Quote
Old 04-18-2012, 02:36 PM   #10
1320racer
1320racer's Avatar
correction, he asked for opinions and all that replied gave theirs.
he also said that a year ago when he signed on. The fact is his car is a bracket car and he a bracket racer!
so did everyone that replied
don't matter, his is NOT a class car!
and your super stock amx isn't this firebird that is a bracket car!
he asked about running radial slicks on a bracket car!
it's obvious that's it YOU that don't get it
this coming from the guy that self proclaims to be..."Arizona's BEST Realtor"
