Old 03-05-2012, 11:36 PM   #6
HP HUNTER
Liked 371 Times in 129 Posts
Default Re: Front springs
Originally Posted by 1320racer View Post
you ain't been on the bumper yet and I used Moog springs on my stock suspension Chevelle...
That said, who makes the spring isn't important, what is important is that you use the tallest spring that will fit with a wire diameter heavy enough to the support the nose weight within 10%, that when compressed at ride height results in a air gap of no more than 1" between the factory snubber on the lower control arm and it's point of contact on the frame
Man Ed, that front end is all over the place, good advice though!
