The NHRA rule book says that if you are running stock with a front-wheel-drive or stock truck, your maximum lift is .430 or OEM which ever is greater. I am running a '77 Pinto with the 2.8L V6 that has .391/.391 stock lift. Can I run .430 lift or does that only apply when this same engine is in a For Ranger truck? Anybody run across this? Thanks.
Liked 54 Times in 18 Posts
It pretty much spells it out to me. Pintos arent trucks or front wheel drive but who knows. Get rid of the fiber top timing gear on your V6, they dont last in stock ones. Put lifters in motor before bolting heads down or you cant get them in . Former Ford mechanics advise.
Thanks for the tips. I've done both already. I think I'll poke NHRA on this though it could be a waste of time. Never know until you try.
The .430 lift rule is for FWD vehicles only. A Pinto is not a FWD car. Trust me, I helped write some of the rules many years ago. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Ford would have to be behind you with that and I seriously doubt that will happen. Do yourself a favor, don't bother tech with such a silly idea. Because they will NEVER listen to you even if you have legitimate grievances.
Jeff Lee 7494 D/S '70 AMX |
How are you going to claim a truck engine when it doesn't show the truck in the guide for 77?
...And that, my friend is the least of your problem with that combo.
Liked 136 Times in 49 Posts
Easy answer is no.
I have always wondered why the rule was this way. If the rest of us have to work with much less lift why do they get extra lift just for being a truck or FWD? |
#8 | |
#9 | |
I'm not sure on the truck deal, but it probably was a similar situation. That big ol' Cajun fella would know....
Ok it all seems fair. So to keep with their being fair to all are they going to give me the same 512/512 lift with the 2.085 int and 1.605 ex valves as the 352 Ford. It is the same HP as my 350 255 (280) small block
