#81 |
Liked 12 Times in 12 Posts
#82 | |
Liked 7 Times in 4 Posts
You can ENTER 2 cars-youCANT drive 2 cars
Jess Suter 7305 Stock/SS Duster "life is not a rehearsal" |
#83 |
Liked 10 Times in 10 Posts
1971,
Ray Allen switches to GoodYear Slicks pc ![]() Last edited by Paul Ceasrine; 08-10-2011 at 10:08 AM. |
#84 |
![]() 1970/1971 LS-6 Intake Manifold Chevrolet Part #3963569 Low-Riser Big Block Dual-Plane Carburetor Holley 800 CFM (1 11/16" x 1 11/16") Square bore carburetor mount / rectangular-shape intake port The Low-Riser was required, to allow for proper hood clearance. Intake was for both the Corvette and Chevelle SS454 LS-6 cars. Last edited by Paul Ceasrine; 08-10-2011 at 10:04 AM. |
#85 |
Banned
Liked 235 Times in 110 Posts
The first National event race Glidden made in Pro stock he was runner up against Grumpy at the world finals LATE in 1972 in a 2nd hand Gapp and Roush Pinto that originally wouldnt go down the track straight when he first tried racing it, he had only one engine, a Ford top loader trans, and a ramp truck to carry it on. Grand total of $10,000 investment.
#86 |
Liked 544 Times in 213 Posts
and the SuperNationals at Ontario...
#87 |
A side view would show the carb mounting pad being nearly lower than the tops of the runners.....
#88 |
Rich,,,,,,,
That's for the Chevy guys to post,,,,,,, I'm Mopar,,,,,,so if I post that photo,,,,,,,,,I will be a Benedict Arnold,, Technical info,,,, The carburetor mounting-base on the #3963569 Low-Riser Intake manifold,,,,,,,,,,only 1.25" above the cylinder head ports... pc |
#89 |
Liked 16 Times in 11 Posts
No body used that manifold, the 1970 rule book stated you could use another gm intake with a max + 1 inch and a 1inch spacer, they all used the highrise untill the rules went to aftermarket intakes.
Bob Pagano A/SA |
#90 |
Bob,,,,,,
Correct,,,,,,,,,,the #3963569 Low-Riser was the factory intake, which nobody used in Super Stock for 1970. but, many racers in 1970, used the 1969 #3933163 Aluminum Dual-Plane High-Riser, which was standard on the 1969 396/375HP and 427/425HP engines,,,,,, or an after-market (ie; Edelbrock or Weiand or Offenhauser) Aluminum Dual-Plane High-riser. pc |
