If you are a mopar guy it is easy to build a big block A Body that will run deep
into 11 Sec. Range and still be a fun low tech Driver. Example: I have a 1969 Valiant with a stock short block 440 with cast 9:1 pistons and a 220 @ .050 cam and single 120lb. seat springs. It has 20,000 Miles on rebuilt with 3.91 gear and stock 340 mopar converter. It weighs 3400 lb. with me in it. Last time out it ran 11.64 @111.82 on pump gas thru 2 1/2 exhaust on street tires. The weather station was 3000 +. Every body at LVMS know the car it has been Pro Track Champion before. and usually finishes near the top ever single year. If you can live with 8 MPG you can drive it anywhere! |
Liked 5 Times in 5 Posts
How much is too much HP for the street? Ask those guys that run Hot Rod magazine's Drag Week competition,,, like Larry Larson and his '66 Nova. He goes to LVMS and runs a 6.93 @ 211, and then an hour later, he cruising the Las Vegas strip. Go to Youtube and check him out.
Danny Durham |
Liked 5 Times in 3 Posts
The 67 Camaro I have is a bit much on the street. It runs mid 12.'s & will make a mess of the rear tires @ will. It's FUN....don't get me wrong but....350 chevy double hump (462) heads 280 Magnum cam Victor jr intake 4.11 gear 750 Holley & tight converter.
#4 | |
Liked 359 Times in 103 Posts
Go Figure |
Liked 66 Times in 29 Posts
you have to see this Larry Larson on you tube,its amazing,on the strip in vegas after wards to pick up his wife at work in a 6.93 @206 mph 66 nova wow
