Old 03-25-2011, 07:44 AM   #1
Kirk Morgan
Liked 80 Times in 44 Posts
Default Quick Fuel 780 SSR carb
The SSR carb has been approved by NHRA as a replacement carb for GM and Ford. Is it approved by IHRA? Any body having any results good or bad with this?
Kirk Morgan is offline   Reply With Quote
Old 03-25-2011, 07:50 AM   #2
Liked 1,826 Times in 414 Posts
Default Re: Quick Fuel 780 SSR carb
We have one. It runs very good, right out of the box. I don't know if it is IHRA approved, you need to call IHRA or Phil Vickus at QuickFuel.
Old 03-25-2011, 01:58 PM   #3
mannymen
Liked 13 Times in 7 Posts
What is different on the SSR 780 carb from a stock 3310. Are the boosters and metering blocks different from stock and have the passages been drilled along with adjustable air bleeds?
N/A
mannymen is offline   Reply With Quote
Old 03-25-2011, 02:48 PM   #4
FINESPLINE
FINESPLINE's Avatar
Jimmy Bridges set the record at 9.167 in SS/C with that carb. on his BB Corvette.
FINESPLINE is offline   Reply With Quote
Old 03-25-2011, 02:50 PM   #5
FINESPLINE
FINESPLINE's Avatar
Jimmy Bridges set the record in SS/C with that carb on his BB Corvette.
Old 03-25-2011, 03:55 PM   #6
Yeah, and when he did it, it was about 95 degrees, around 80% relative humidity, and the density altitude was around 3000 feet.
Old 03-25-2011, 04:04 PM   #7
FINESPLINE
FINESPLINE's Avatar
Not exactly the type of day to make a record run. He should try Atco in the spring or the Dutch in the fall. That motor was sucking some air !
Old 03-26-2011, 02:14 AM   #8
Jeff Lee
Jeff Lee's Avatar
The QF 780 has metering block on the rear, the 3310 has a plate. The QF has 4 corner a/f screws, the 3310 has primary only. The QF has adjustable vacuum to the secondary diaphragm to control opening rate, the 3310 requires a spring change. The QF has replaceable air bleeds were the 3310 bleeds are fixed. The QF has throttle blade angle adjustment on the secondaries that is external and easy to get to. The QF is much lighter & made of aluminum, the 3310 is cast zinc (?).
I still like the classic gold of the 3310 best.
That's basically it. Oh, retail for the 3310 is about $275 and the QF is about $525
Jeff Lee 7494 D/S '70 AMX
Old 03-26-2011, 09:01 AM   #9
Greg Hill
Liked 279 Times in 68 Posts
Jeff the original 3310 has a metering block in the back and was rated at 780 cfm.
Greg Hill 4171 STK
Old 03-26-2011, 09:12 AM   #10
Adger Smith
Liked 880 Times in 311 Posts
I have an e-mail from Mike Baker that says the Quick Fuel carbs are approved in IHRA. I was asking for one of my Crate Mtr. customers.
The blocks in the back of 3310's came on the 3310-1 and -2's Rated 780. They then went to some plastic parts and changed the down leg boosters to straight leg and re rated the later 3310's to 750. Those had the plates in the rear. My memory on the change might be a little fuzzy. It might have changed with the 3310-3 to 3310-4. I'm almost positive all the 3310-1's and 2's have rear metering blocks. I guess I could dig out my old Holley books and check it.
Adger Smith (Former SS)
