Old 03-07-2011, 07:42 PM   #1
Pvt Parts
Pvt Parts's Avatar
Default Re: Engine Shut Down
Originally Posted by Bob View Post
My question about a 6.00 gear was based on his statement of a 305 Stocker. He said:
"why would I put a 6.00 gear behind my bb/turbo400 combo?
That said, we've got that gear behind a 305 stocker and count it amongst those that ain't clicking it off at the stripe!"
I don't know of any LEGAL 305 powered stockers that use a Ford 9"
In that case I'd refer to the second part of my response..... "have one made....." if you really need it.
Old 03-09-2011, 10:11 AM   #2
Bob
Originally Posted by Pvt Parts View Post
That's a std ratio for a 9" Ford maybe available for other center sections now as well. If not, you have one custom made. I've had custom gear sets made for 5 speed transmissions that you could not buy off of the shelf.
Could you please give us the name and number to the company you have making these parts for you.
I'm only asking because I was under the impression that manufacturing a ring/pinion would take very special equipment like CAD design, milling, turning, hobbing, heat treat, etc.
As well, I did not know there was a company that would build just one set.
If you search the forum, you will find the thread on the 5.00 gears that were custom made by Richmond. Besides the time and effort involved by the people who organized the production, I think they had to have 49 sets made.
It would be nice to know the name of a company that would side step all these obstacles and produce a one off gearset.
Thanks in advance for the name and number.
Bob is offline   Reply With Quote
Old 03-09-2011, 05:12 PM   #3
Jeff Lee
Jeff Lee's Avatar
Anything can be bought with enough money!
Jeff Lee 7494 D/S '70 AMX
Old 03-09-2011, 07:56 PM   #4
Pvt Parts
Pvt Parts's Avatar
I had a lot of custom parts made for my cars back in the late 1980's including the first prototype "all roller bearing" 4 speed made by G&G transmissions that I ran in SS/A & B. George also made a couple of custom ratios for me that I used in that transmission when I ran it in SS/AM. I believe I was the first drag racer to run a carbon fiber driveshaft. That was in '89 or '90. I located a guy in Michigan who was making them for the Porsche teams and Roger Penske. When I moved to comp, Craig Liberty made an ultra low gearset for my clutchless 5 speed that I ran in C/SM and H/A. David Nickens built a couple sets of split dominators that we ran in B/A and C/A. I know that Glidden ran that combination for a while before they were banned in Pro Stock. Ball bearing carriers in a 9" Ford center section was another one. (Not pinion support, but the bearings on the spool.) I know that some if not most of these items are available "off of the shelf" now but back then you had to make em yourself or have them made. A number of the Pro Stock guys back then had custom ring and pinion sets. I believe they were made by Richmond Gear. I'd check with G&G or Craig Liberty if I needed one today. Going fast in this game is a 24/7 job and it's expensive. If you are not working on the car, you are building new parts and/or renting the race track to test them. We used to rent IRP for $1,500.00 per day to test new combinations. We were the only car there.
Old 03-09-2011, 08:59 PM   #5
RULER
Liked 58 Times in 18 Posts
Well one thing for dam sure is there aren't any good running 305 stockers out there with a 6.00 gear in them, custom gear or not!! the only way that gear would have a chance of working would be in the 1/8 mile or like somebody said at Denver on a hot summer day.
RULER is offline   Reply With Quote
Old 03-10-2011, 12:40 AM   #6
JeremyDuncan
Liked 355 Times in 80 Posts
Strange makes a 6.00 12 bolt pro gear. Have used them on occasions.
http://www.strangeengineering.net/catalog/index.html
part# RP01988600
BTW Raced for almost 18 years and have always shifted to neutral (PG, turbos, Pro Trans, and Torque Flites) and shut the motor off at the strip.
JeremyDuncan is online now   Reply With Quote
Old 03-10-2011, 09:31 AM   #7
Ed Wright
Ed Wright's Avatar
That applies to most, other than a certain NJ bracket Racer's buddies.
Ed Wright 4156 SS/JA
