Liked 4 Times in 4 Posts
I have several blocks that were already machined but a thunder storm blew out the back wall of the garage and the humidity caused the blocks to surface rust on all machined surfaces.
Anyone know a good way to clean them up? JimR
Jim Rountree |
Liked 333 Times in 180 Posts
ever try soda blasting??? Seems to work with no metal removal---you blast it, wash it off with water then blow dry to remove water and spray Blaster or a marine fogger to protect from rusting--Comp 387
another product is
called Rust lick----Comp |
Liked 882 Times in 236 Posts
Jim, You can try getting a bottle of metal prep solution from ypur local body supply house......It's a very dilute acid made for prepping bare metal before bodywork. ...I've used it to clean cylinder walls that had light rust. .........just be sure to neutralize the surfaces with clear water and blow dry before oiling them down
We have used vinegar for rust on guns and tools. Works pretty well, plus it should kill any yeast infection.
![]() Don |
Liked 880 Times in 311 Posts
Try Evapo-Rust... Works good at my shop and I've been told other shops use it.
Adger Smith (Former SS) |
Liked 6 Times in 4 Posts
Try CLR.....
Liked 19 Times in 8 Posts
CLR works great my need several applications it's available at the Home Depot and Lowes
Joe Schweigert 751 SS |
Liked 263 Times in 68 Posts
I have used scotch brite pads and WD-40.
John Dinkel 3295 STK |
Thanks Guys,
I used everybody's suggestions and the block melted.....lol! Thanks for the help, JimR
Jim Rountree |
