Old 08-16-2010, 12:54 PM   #1
Ed Wright
Ed Wright's Avatar
Default About dry ice...
Has anybody found how to keep this stuff longer than 12 hours or so?
Ed Wright 4156 SS/JA
Old 08-16-2010, 02:08 PM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: About dry ice...
Ed,
The 25/30 lb. block , will last the longest .... ( but is hardest to use )
The smaller pellets are great but only last 8 -12 hours ... Must be kept
in a sealed cooler, with no leaks ? In shipping packages around the world, we used a block covered over by pellets.... this would last 3-5 days.... Hope this helps.....
Dave Ribeiro 1033 STK
Old 08-16-2010, 04:16 PM   #3
Mark Lewis
Liked 207 Times in 44 Posts
Default Re: About dry ice...
Dave, I will take a block as long as it is covering some lobster, lol.
Mark
Mark Lewis is offline   Reply With Quote
Old 08-16-2010, 04:41 PM   #4
Dave Ribeiro
Hey Mark,
Do you want the Lobsters Live or Dead , you know everything must be kept from touching the dry-ice ... It will burn anything it comes in contact with , so layers of papers must be rapped around the Dry-Ice when shipping food products...
Hope you are doing well .... take care, Dave
Old 08-16-2010, 05:52 PM   #5
Whalen3186
Liked 109 Times in 32 Posts
The less air space you have in the cooler, the better off you are too. Packing the cooler with newspaper to fill the empty space will help and keep the cooler sealed at tightly as possible, might even want to saran wrap the lid shut.
Whalen3186 is offline   Reply With Quote
Old 08-16-2010, 07:48 PM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
we can get about 30 hours out of 50 lbs packed in brown bags and newspaper stored in a cooler,,when a coach looses a axle bearing and destroys the axle tube, we use dry ice to shrink the new tube and install ,,they need to be on ice for 24hrs and theres always plenty left over gmonde
Old 08-16-2010, 08:03 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I was doing some work for a bus company in Boston......Prevost......A bus burned up a freshly installed rear axle bearing probably due to the mechanic assembling it dry.......It was towed back into the shop where a mechanic or two spent the better part of a day trying to remove the damaged stub......A lot of tricks failed and I got an education on work I don't want to do!
I was working repairing seats.......
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 08-17-2010, 12:04 PM   #8
Ed Wright
Ed Wright's Avatar
Thanks guys!!
Old 08-17-2010, 12:14 PM   #9
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Ed are you coming to Crandall in Sept?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 08-17-2010, 02:27 PM   #10
Greg Barsamian
Liked 427 Times in 97 Posts
We use Liquid Nitrogen to shink bushings to fit them into Platens & links of injection molding machines.
