You guys do know a lot of tech guys read this stuff, right?
I would not put rock salt in my fuel cel. But, that's just me.
Ed Wright 4156 SS/JA |
Liked 13 Times in 7 Posts
Why doesn't one use smaller cooler/freezer packs instead?
N/A |
Liked 216 Times in 77 Posts
why cant you just drain the fuel between rounds put it in a jug and pack the jug in ice. before you go up to run put your cold fuel back in the cell.
As far as on the return side I noticed that the fuel in my fuel injected bracket car would get really warm in late rounds. I figure its pulling heat through the alum rails bolted to the aluminum intake. Since nobody makes a cool can cabable of being used in a high pressure system I put one on the return side. Save your money on this idea as it did not even come close to cooling the fuel fast enough to make a differnce. |
#4 | |
Liked 49 Times in 15 Posts
I realize tech guys read this. Are you saying cooling your fuel is illegal? The rule book says: Fuel/Air: Any method of artificially cooling or heating fuel prohibited (i.e., cool cans, Freon, wet rags, etc.), except as noted in Class Requirements. Cool cans, wet towels, etc. are permitted in Super Stock, Stock, Super Comp, Super Gas, Super Street, and E.T. classes. Wet towels, rags, ice, etc. must be removed before vehicle leaves staging area. Ambient-temperature air only; cooling or otherwise changing the conditions of the intake air is prohibited. Spraying of intake with any artificial spray or coolant prohibited Cooling your fuel has been going on forever. And every time NHRA checks your fuel they are also taking a temperature reading on it. If you are any good at it, the fuel is still going to be cold when you do a fuel test, unless you stand there warming your sample.
Dean Feiock -- Stock 5002 |
I'm sure that is what he mean, Dean. Should have added a smiley.
I'm not sure what they would think about dry ice. May not care. I would't want to find out the hard way they don't like it. They looked at a friend's car & fuel system here at the Tulsa LODRS race because it checked too cold. He had not done anything, evidently a mistake or the thermometer was wrong at the fuel check desk.
#6 | |
Danny Waters, Sr / 73 Duster "340" |
Guest
Posts: n/a
Cool cans no! The vapor pressure of our racing VP is @ 700 degrees f. I can make our manifold an induction heater and possibly vaporize the gasoline to the threshold of a real atomized gas....that is the trick...competition eliminate and pro stock guys should have had they cubic money hands on this a long time ago..I know if I had cubic money like some of these guys you'd have to kill me...I'm talking Hagan industries to the Nth power....can you say out side of the box?
#8 | |
You guys need to try that on your car. Get back to us with how fast it is, OK?
#9 | |
The rules specifically state that cool cans are ok, in no less than two places in the rule book. If you are allowed cool cans, how can you not be allowed to present a cold fuel sample? And honestly, on most days, by the time you take the sample, walk over and stand in line with the cup in your hand, the fuel has warmed quite alot anyway.
I'm sure I'll get a lot of S**T for this but I don't owe this to anyone I discovered it on my own.
You take Dry Ice and put it directly in a 5 gallon fuel jug with about 3 gallons of gas. Small chunks, no cap as they disapeer you ad more till it gets to the temperature you want. I though you stock superstock racers would have figured this out yourselves. I guess it doesn't cost much so it goes below the radar.
Art Leong 2095 SS |
