Old 07-27-2010, 12:02 AM   #11
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: getting started
Originally Posted by ssdeuce View Post
how bout the suspension front can't have any aftermarket control arms but can change bushings correct, and the rears can be aftermarket but have to be nhra approved how do i know which are or aren't. also can i use an aftermarket trans crossmember for a th350 in the g body that i didn't find in the rulebook.
Under the Competiton tab of the NHRA Site, there is a link to Accepted Products
Here is the direct link.
http://www.nhra.com/userfiles/file/N...roducts-11.pdf
I would read it and learn everything about your engine / options / desires you can, in my case I have been limited because of the lack of availability of approved products for the package I last worked on.
BUT for you .... it should be chock full of dollar spending goodness.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
