Old 05-12-2010, 06:21 AM   #1
Marc Kinton
Default Another turbo ?
Ok, we got the air/fuel ratio installed and I'm getting a reading of 11.2 or so on the O2. I'm assuming this means the car is too lean? I have heard we were looking for mid 12's on this reading. Two part question, am I correct that it is too lean and do I just adjust fuel pressure for this or fuel and timing? This is a 4 cylinder turbo ford combo stocker.
Marc Kinton is offline   Reply With Quote
Old 05-12-2010, 07:27 AM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Another turbo ?
To rich... 11.2 parts of air to 1 part fuel. I have found 12.8 or so seems to make the best power (12.8 or 13.0 parts air to one part fuel). I hope this helps.
Oh, and to some extent it is better to be a little rich than lean...but you knew that.
Bill
Bill Grubbs is offline   Reply With Quote
Old 05-12-2010, 08:31 AM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
You didn't say when you're seeing this AFR. Under load, Idleing? 12's under full load on a turbo setup sounds a bit on the lean side, however I'm surew that there are a few turbo racers on this forum that can help. Joe
Joe Buchanan SS/BX 3117
Old 05-13-2010, 01:27 PM   #4
Ed Wright
Ed Wright's Avatar
I have only tuned street cars with turbos, but those won't live long leaner than 12.0-1.
Mid elevens works well, and leaner shows very little power increase with a turbo.
12.8-1 & 13-1 are normally aspirated numbers.
Ed Wright 4156 SS/JA
Old 05-13-2010, 01:38 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Another turbo ?
11.2 A/F in a turbo race motor under load is ok. Better too rich that too lean, especially a turbo engine! You would be surprised how quickly those pistons go from being a solid to a liquid! Jim
2009 D2 National Open Stock Champion
1981 D2 West Palm Beach LDRS SS Runner Up
Old 05-13-2010, 04:26 PM   #6
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Marc, shot you a message on FB. Get back at me!
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 05-14-2010, 08:45 PM   #7
Jimi B
Just backing up what others have said. Mid 11s is about where you wanna be on higher octane pump fuels. Around 12:1 or so on higher octane race fuels. There is a lot to play with afrs on spool as well, but in a drag car this is not going to be that usefull.. Especially if its a stock turbo, prob spooling fairly well anyway..
Jimmy Bowling BF/S 3808
www.facebook.com/jimib1980
Jimi B is offline   Reply With Quote
Old 05-17-2010, 07:03 PM   #8
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
that's the question - how much boost? My car drops more than 2 whole numbers from 12.x staging to 9.x @ 18 lbs boost.
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 05-17-2010, 11:23 PM   #9
Jimi B
Why?
Old 05-19-2010, 12:04 PM   #10
Harry 6674
Lots a variables. Tell us about your setup.
Harry 6674 is offline   Reply With Quote
