I assume the pedal is rising after pumping. The posts cover 99% of what I've seen may cause your problem but if you are pressure bleeding the system correctly (closest to farthest point without an "X" system) I would take a real good look at Mr. Zlatkin's post. Also, make sure the master is what you think it is. (1" bore)
