Old 01-01-2010, 11:29 AM   #5
njk53
Default Re: Oooopppsss tranny cooler suggestions ?
I agree with Pat also. Do you have a cooler intank to the radiator? If so, use it, that should be sufficient. If you don't have an intank cooler just take a piece of transmission line material and bend it in an "S" shape about a foot wide 3 passes high and mount it in front of the radiator to create a heat sink.
It takes an enormous amount of slip heat in the transmission to create enough heat to get you the danger zone.
A lot of guys will eliminate their lines from the intank cooler and go to a remote (air to oil) cooler which is a mistake. An intank cooler is approx.
2 degrees cooler than an external cooler.
Nelson Kowal
Stock 345
