Old 11-19-2009, 07:48 PM   #1
Bob Gullett
Bob Gullett's Avatar
Liked 464 Times in 113 Posts
Default Schubek Lifters
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 11-19-2009, 09:31 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Schubek Lifters
Daryl Wikle is a rep for Smith. He provided mine two months ago. His number is 316-942-9500
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 11-20-2009, 12:56 AM   #3
GTX JOHN
Liked 2,462 Times in 694 Posts
Unhappy Re: Schubek Lifters
Smith Machine out of Cedar City, Utah now is the builder of these lifters. My understanding is he is the old shop foreman when they were in vegas. Better buy a bunch because the quality control is even worse than before......First set two broken plungers and one bottom that came loose in first set I bought in first five runs!!!
Old 11-20-2009, 01:08 AM   #4
Jeff Lee
Jeff Lee's Avatar
Your lucky you found the problem before it got real serious. I can attest to the damages when one of the pucks do come off.
Jeff Lee 7494 D/S '70 AMX
Old 11-20-2009, 11:50 AM   #5
Casey Miles
Liked 488 Times in 90 Posts
Thumbs up Re: Schubek Lifters
Two engines, never put them in my car again! Use the steel billet or the ones with EDM and ramp up the spring pressure.
Casey Miles
248H
Old 11-20-2009, 01:33 PM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
Question Re: Schubek Lifters
So have you had problems with the Schubeck or the Smith lifters?
Old 11-20-2009, 03:38 PM   #7
Casey Miles
I had Schubeck and I'm not say that they aren't a good product,but I still wouldn't take a chance on anything like them any longer. If you even chip one, get ready to take the motor out , buy new pistons and also reboring the block. Never mind all the other small parts you have to replace. (oil pump, camshaft, bearings, and on and on.)
Casey Miles
248H
Old 11-20-2009, 04:03 PM   #8
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: Schubek Lifters
Casey Miles
248H
I know its beating a dead horse but if the valve spring rule had never been changed to any pressure the lifter problem and cost would not be there. NHRA should have just gone ot a standard pressure across the board for all models and brands of engines that would allow equal performance for everyone without the expense of using something like a Shubeck type lifter...... something around 150 lbs on the seat and 350 lbs open and these hi RPM shift points would go away (more savings) . Oh well then they would have to check valve spring pressures at tear down again. To much work I guess.
Old 11-20-2009, 04:56 PM   #9
Liked 5,109 Times in 1,947 Posts
Yep ,Terry. Then you wouldn't need weldments added to the pushrod cup on OEM type rockers, only on certain brands.
Old 11-20-2009, 05:10 PM   #10
X-TECH MAN
Banned
Talking Re: Schubek Lifters
So what we have is another Super Stock class with a tire size limit and spec cam lift. The heads are "almost" the same....lol.
