Liked 8 Times in 7 Posts
who's spools/axles do ya like/don't like? (keep in mind this'll be a 3200lb 12-13 sec car) what spline count?
is it legal to put a nice big inspection hole in the housing? |
Liked 263 Times in 68 Posts
I have had very good luck with Strange. Use the 35 spline axles. They will last for a long time.
You could get the lightend axles and 5/8 wheek studs for a few dollars more. Good luck.
John Dinkel 3295 STK |
Liked 138 Times in 51 Posts
I've been using Moser products for years and am very happy with them. 35 spline axles and spool are quite a bit stronger than 30 spline. But it doesn't hurt to have an extra margin of strength. 35 spline are more popular and easier to sell if the need arises. A steel billet yoke is also an extra durable piece because OEM yokes can eventually spread. 12-13 second range vehicle would do well either way.
If you do want to inspect the gears and weld something into the housing, you might as well have it straightened, weld a filler cap near the top which can double as an inspection hole, and consider a brace.
LOCOMOTION Racing |
Liked 4 Times in 4 Posts
I chose the Moser spool and 35 spline axles for my Max Wedge stocker but when I bracket raced the car with a 440 and X-ram I ran stock axles and a stock sure-grip with 11 inch tires and never had a problem running mid to low 11's.
Jim
Jim Rountree |
#5 | |
I don't see why not but you'll have to check the rulebook on that one. By-Run "Be a good sport at the drags... help your competitor O-U-T!" Last edited by ET6201; 07-02-2009 at 07:42 PM. |
Liked 6 Times in 4 Posts
I just paid $550.00 for a set of Moser 30-spline axles, and am not very happy with some aspects of them.
Nothing big, but some little stuff that shouldn't have happened, in my opinion, especially from a well-respected company like Moser, who built their reputation with mainly MOPAR components. To wit: 1. Wheels studs were not fully machined where the screw-in threads end, and have a space that then becomes wheel attachment threads. They wouldn't screw in all the way and I discovered that the empty space between the two sets of threads needed to be machined (turned down smaller) for them to seat fully in the axle flange. Had to have that machined, or they wouldn't screw al the way in. Not doing this would have kept the inner lock-nuts from screwing all the way down to the axle flange material for securing the stud from turning. 2. None of the drilled holes in the flanges were "clean," around the edges. I had to take a chamfer tool and clean up the left-over metal from the drilling process still attached to the edge of the holes. 3. Mopar 8.75" axle flanges have an access hole (and two smaller holes on the opposite side, for balance) to allow a socket/extension to pass through the flange, and engage the five 9/16" nuts that hold the bearing retainer plate secure, so you can quickly and easily remove the axle. These axles were missing those holes, so I took them to a local machine shop and got them "installed"... another expense that I felt should have not been incurred, given the price of these axles. Otherwise, they seem to be A-1. Maybe this is nit-picking, but if Moser wants to maintain their excellent reputation, I felt like these items shouldn't have happened. My 2-cents... Bill
Bill Last edited by bill dedman; 07-03-2009 at 02:27 PM. |
For #1, if I understand it correctly, could there be a washer that goes there?
#3 - I don't recall seeing a set of race axles that had the extra holes in the flange, Strange included.
LOCOMOTION Racing |
Liked 242 Times in 81 Posts
Mark Williams makes the best axles and components. I bought my first set of Williams axles 30 spline in 1974 for use in a 340 stick shift stocker They finally gave up the ghost in the early 90"s. Hard to beat that. Their axles are built for the application not a generic long sline cut off. Only my 2 cents
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Myron,
The hardware (lug nuts, studs, thick spacer washers, etc.) were all together, in a box, and seemed very complete, but there were no washers for that purpose included. I don't think a washer is a part of that deal. The holes that were not there might be a strength consideration, but have you ever seen an axle flange break or distort the flange itself, because of a strength issue? I haven't, and don't think that's a viable consideration in this case. But, I've been wrong before... could be, again... Thanks for your input!!! Bill
Bill Last edited by bill dedman; 07-03-2009 at 07:16 PM. |
#10 | |
i'm thinking you're right,http://www.markwilliams.com/axles.aspx |
