We are planning a S/G build; 2600# '66 mustang 2dr cpe, Alston full tube chassis kit, Fbrgls front end and doors,
Looking for the best engine/trans/rear end ratio combo for this class. Need some advice, first time to put together one of these. |
Banned
Not real sure of the ford motor, but you should have 800 hp. A C4 with a probrake and 457 rear gear and also the converter should flash @ 6000 rpm Good Luck !
Liked 3 Times in 2 Posts
If you want to run a Ford motor, make it a big-un. 557 BBF's are easily available on Racing Junk in Short block or long blocks. Good heads, nad decent roller cam should get the job done. For a trans stay away from any FORD trans, save the aggrivation and go right to a glide with the JW Ultra Bell. Run a 14x32 tire, should be able to run a 4:11 maybe a 4:30 gear.
I am finishing a 90 Mustang but I am using a 28x10.5 tire and a 3.73 gear on my 557/glide combo. Motor makes 800+ hp. I am looking to get this thing to go at least 9.3's
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Liked 21 Times in 6 Posts
Give me a call we have a diaper that fits the Fords good
![]() Dennis do you have one that works with the aftermarket K frames?
#6 | |
Liked 691 Times in 199 Posts
(Ran 9.50's off the stop) Used a 427 block, stock tunnel port heads and intake and a flat tappet cam with .653 lift. (It could red light with the power glide without some delay. Struggled with the C-6) Cheaper to use a 385 engine but like the others said stick with the glide. Last edited by Mike Gray; 06-18-2009 at 02:59 PM. |
