Liked 20 Times in 15 Posts
Is there a replacement carb for the Carter AFB 3854S? Thanks
Liked 419 Times in 85 Posts
no you have to find originals
Liked 8 Times in 7 Posts
maybe.
at least nhra lists a couple for my rambler. and if it's LIKE my rambler, rotsa ruck! i found a builder on ebay, cost me a 100 bucks and i STILL have to go thru it... |
Liked 780 Times in 194 Posts
Actually, theat's not totally true. You have to have a model that is the same type (Carter AFB and derivatives) and the same measurements (1.437 x 1.562 throttles, 1.062 x 1.250 venturis). It does not have to be the exact model number. There were lots of AFBs built during that time period with those dimensions, but I do not know any modern replacement. As always, be sure to ask your divisional director about your choice before spending a bunch of money on it.
Liked 70 Times in 29 Posts
what type of combo is the AFB for?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 16 Times in 11 Posts
Mopar 273 if I remember the number, I am trying to remember its size (cfm) that would help him find a replacement.
Bob Pagano A/SA |
Liked 333 Times in 180 Posts
not sure but isnt 3853s the same carb ---only dif is one is for auto and the other manual trans---comp 387
Sorry I was not that clear. There are 9 carbs that have the appropriate measurments, but they are all originals. I tried to get a replacement approved with no success. Your appoved Carter numbers are as follows.
3853, 3854,4119, 4120, 4122, 4294, 4295, 4304, 4305. Good luck because they are usually in poor shape. The carb works fine for 273 cubic inches. |
There are some other numbers from the 1960-62 years that are the same size, but I doubt if you could find them in any better condition than the later years when that size carb was used on the 273s.
Classic cars and parts in Fountain Inn SC. I have been to their yard and they have tons of old carbs and other original parts in boxes along with some pretty decent rollers and part cars. Hope this helps. They also have some new parts from the 60's and 70's still in the boxes!
Classic Cars of Sc www.classiccarsofsc.com 2424 S Frontage Rd Gray Court, SC 29645 (864) 963-8917 Last edited by Floyd Gomez; 05-20-2009 at 09:21 PM. |
