Old 02-23-2009, 09:34 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Adjustment for Turbo Action shifter?
I removed the B&M shifter that came in my duster with a used Turbo Action shifter.
I put the trans in park, then removed the cable.
Put the Turbo Action shifter in, ran the cable and hooked it up to the same bracket
that was on the trans. Was this a mistake? the shift pattern is PRN321 with a manul
valve body. It will shift into PRN3, but not 2 or 1. Am I missing a bracket.
The cable that bolts to the trans ear and holds the cable in place came with the shifter.
I can call Turbo Action tech line tomorrow, the only bracket that came with the T/A
shifter looks the same as the kick down lever that was wired to the rear and not used.
Opinions and advice???
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 02-23-2009, 10:20 PM   #2
rgarvey
Default Re: Adjustment for Turbo Action shifter?
you have to use the shift lever for the turbo-action shifter the old one you have will not work
rgarvey is offline   Reply With Quote
Old 02-24-2009, 12:51 AM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Adjustment for Turbo Action shifter?
I agree. I had the exact same situation with my SS Demon, except I had a 727 not a 904. Also make sure you have the shifter for the reverse valve body. Jim
2009 D2 National Open Stock Champion
1981 D2 West Palm Beach LDRS SS Runner Up
Old 02-24-2009, 12:59 AM   #4
69ss/rs
The Turbo Action shifter is one of the easiest to adjust, as long as you use their shifter arm on the trans. To set the adjustment you must put the shifter in neutral, put the tranny linkage in neutral; line the two up and you should be good to go.
69ss/rs is offline   Reply With Quote
Old 02-24-2009, 08:06 PM   #5
Philip Saran
Thanks for all the input. I called and talked with Paul @ Turbo Action
today and he set me straight on what I need to change and how to
adjust the linkage.
Phil Saran
Parker, Colorado
