Old 03-15-2025, 07:10 PM   #12
Liked 1,932 Times in 435 Posts
Default Re: 427 BBC pistons closed chamber ideas or?
Originally Posted by sean1970ss View Post
I found one of my cams but the duration is over 300 .748 .748 112 cn for 250 shot of NOS. I looked in wiseco they have a nice set 4.310 bore. I can use any type of manifold and carb or tunnel ram. Going to scan the cards see what you think.
Thank you very much this is just a build I have always wanted to do for the heck of it. Slick Rick is doing my 291 heads,
Yep, the Wiseco stuff is nice. Vic Ellenger can get you a nice package, Total Seal rings and Trend wrist pins.
That cam isn't what you want. Way too much duration, not enough lift. You're going to want to be in the 0.850" range on lift, and 288/296/108-110 on duration, you need a custom for what you're doing. A good tall single plane single 4V intake will do fine. I'd use a big 4150, maybe a 1050 with annular discharge boosters, talk to Trevor Wiggins at Get'Em Garage.
You're going to want T&D or Jesel rockers, 1.75:1, or maybe 1.8:!, depending on the cam, and I'd use Ferrea hollow stem valves, the Comp 1.560" dual spring and tool steel retainer, they have some of those that are lighter than a triple spring with titanium retainers, and they're a better spring, higher quality material and finishing.
