Liked 7,854 Times in 1,750 Posts
Well, it DOES make it easier to fix "bump-steer".
Liked 53 Times in 38 Posts
If I heard right, one long time stock racer I talked with said the QA1 strut bar was allowed now on his car (Demon).? Back to square one if not allowed.
#3 | |
SUSPENSION, FRONT Must retain complete stock front-suspension system as produced by manufacturer for body used. Lift kits/travel limiters permitted. Sway bar optional. Aftermarket tie rods with heim joints permitted. Lower control arm may be machined for larger shock diameter and mount. Strut rods with heim joints or spherical bearings permitted. Electric shocks prohibited. |
#4 | |
Liked 5,145 Times in 1,964 Posts
I know, when I was helping out a bit on the Tbolt, about 6-7 years ago, they weren't allowed. That was source of movement that was not good. Some of you might have noticed a bracket car or two with bad bushings. Seeing the front wheels move back and forth while staging was a REAL safety issue.
#5 | |
You are correct! It took NHRA some time to understand it was a safety issue, especially after a wheelstand. As I understand, it was Troy Olsonawski who brought up the issue with NHRA and the actual risk. |
Great news, with mine now there is no movement front and back when wheels are in air back to normal height. A lot of time went into fixing that and the bump steer.
Liked 19 Times in 10 Posts
I reached out to NHRA and got this response??? Definitely more confused than ever.
" Are you asking if the strut rod can have spherical rod ends; if so the answer is no for Stock Eliminator, They are permitted in Super Stock." Pat Cvengros Pacific Division Technical Director |
#8 | |
Where did you find this??? |
#9 | |
Liked 755 Times in 213 Posts
