Old 04-26-2023, 04:48 PM   #1
Woodfin
Liked 274 Times in 105 Posts
Default Re: East Coast Auto Electric - owner retired
An auto parts store that is equipped with an alternator tester can the job. It is not complicated nor high tech. You can also bench test it with a drill and battery and jumper wires. If the alternator puts out at drill speed and sounds normal, it will put out at higher speeds. You are simply looking for voltage, the amperage output will be OK if the voltage is in range. [of course, there are always unusual exceptions but in general, this is true]
Old 04-27-2023, 07:55 AM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Thanks Larry!
