Old 09-05-2022, 11:17 AM   #6
Steve Stasko
Liked 287 Times in 146 Posts
Default Re: 67 Barracuda front suspension
Originally Posted by THROWER2010 View Post
The car works great most of the time. I have installed custom valve shocks by Jeremy at competive suspensions. i have them full loose at "bad" tracks. I would like the car to pitch rotate better. My thought is if i can get rid of the upper rubber bushings and get the suspension to be "looser", car will work better on bad tracks. then on good tracks like Galot and can tighten extension. It's nose heavy with bbm.
I figured this was the place to ask because of the stocker and super stockers using factory style frontend.
Thank you
Have you tried taking some rebound out of the rear shocks on the "bad" tracks?
