Old 08-20-2016, 12:18 PM   #10
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 4-spd Transmission Choice for lower class Ford US/VS/WS
Originally Posted by PROSTOCKTOM View Post
8.8" would probably use less HP, but he already has a good supply of 9" parts.
Plus it's easier to change if we break one at the track.
Back to the transmission discussion
Tom
How in the world would you break a 9 inch with a Pinto motor?The 8.8 would be the logical choice due to size,weight,cost and availability. If 6.14's are available, so would anything else you would need.The 8.8 uses some of the same internal bearings as a 12 bolt.It would definitely be more low friction than the 9 inch.
