Old 12-20-2015, 12:12 PM   #13
Mike Pearson
Mike Pearson's Avatar
Liked 2,015 Times in 605 Posts
Default Re: Racing seats
Originally Posted by Eman View Post
On a stock floorpan car how are you mounting the seats? On thru bolting the plastic seats are you using carriage style smooth head bolts? Are you drillng thru where the inserts are?
I welded some threaded inserts into the floor pan similar to the stock seat mounts. I drilled the threads out of the seat inserts an used a 3/8 grade 8 bolt with a large flat washer to bolt through the bottom of the seat to the floor. 1 half inch bolt through the back into the cross bar
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
