Old 11-15-2015, 02:41 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default F body oil pan cut out
Stock elm here we come. Can we get a few pics of how much to notch out the cross member on a 4th gen with a LS1 for oil pan removal . Thanks for now Tom
Tom Meyer 5240 SS Stock ???
Old 11-15-2015, 03:34 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: F body oil pan cut out
this what I have done in a few stockers. you wont need as much in your car . but it may life easy when you have to drop the pan .
Name:	x member.jpg
ID:	31704   Click image for larger version
Name:	x member 1.jpg
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 11-15-2015, 03:38 PM   #3
Mark Markow
pics posted
Mark Markow
171 ss/tb
Old 11-15-2015, 05:13 PM   #4
Liked 2,050 Times in 398 Posts
Talking Re: F body oil pan cut out
Nice work Mark ...............
Old 11-18-2015, 07:11 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
Mr Markow. If I were to send you a K member. What do you charge to do that?
PM me if you would rather.
Thanks
Rob
Old 11-18-2015, 07:35 PM   #6
Mark Markow
Thanks
Rob
pm sent.
Mark Markow
171 ss/tb
Old 12-03-2015, 10:44 PM   #7
jmantle
Liked 172 Times in 81 Posts
Nice work, just what I need. I ran it past our div 6 tech guy and was a little surprised at his response,
Hi Jim. Got the low down on the wording interpretation on the removable crossmember. Apparently the removable wording only allows you to have removable pieces of the crossmember. It does not mean that you can have a removable section of the crossmember. Basically you can cut up the crossmember but you can't cut through it.
Dave
Has anyone had any issues with tech in other divisions?
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 12-04-2015, 02:03 AM   #8
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
That makes no sense? This mod to allow pulling the oil pan as Mark showed has been allowed since around 2008.
Under Stock Rulebook page 131
OIL PAN
OEM or NHRA-accepted aftermarket replacement oil pan
permitted. Windage trays and/or baffles permitted. Modifications
of any kind prohibited. Crossmember may be altered for oil pan
removal. If altered, all material and strength must be replaced by
boxing or installing removable or permanent material.
Sean Marconette
84 Mustang
5060 SS/N
Old 12-04-2015, 06:31 AM   #9
Lee Valentine
Liked 319 Times in 68 Posts
Your Tech man is an idiot.
Lee Valentine 1661 STK
Old 12-04-2015, 03:40 PM   #10
jmantle
I don't think that was called for as his response came after he contacted Glendora.
Jim Mantle
