#21 | |
Liked 116 Times in 27 Posts
#22 |
Rich, its fairly easy to buy all the parts you need to build a 352. The only thing you need from Ford is the heads intake and throttle body. Everything else can be bought through the aftermarket. I would go with the boss block from Ford, its a great piece that needs very little machining.
Steve, not sure about your combo, but my old combo does not using many oem parts. Such as rods, pistons, cam, valves, and on on. Everything you need for a 352 or 428 is available from Ford. Everything else is available through the aftermarket. Not sure what your point is other than the HP factor, which is really not part of this topic. |
#23 | |
#24 |
Rich, you do not need the badges just hood and grille, the link below is just one place your can get the hood. You can get the grille also, but through Ford only. I will give more info on were to get the grille by the end of the day.
http://www.summitracing.com/search?k...16612-CJ&dds=1 |
#25 | |
#26 |
Liked 7 Times in 5 Posts
Rich,
Ford Racing no longer offers the grille and hood. You may want to Google the part numbers and see what you can find. The grille is M-5767-CJ10 and the hood is M-16612-CJ. The special motor mounts are still available to put the Windsor style engine in the S197 Mustang. regards, Roland |
#27 |
Liked 26 Times in 11 Posts
Call Ken Sabo at Varsity Ford Ann Arbor Michigan for CJ parts, I know he has a couple of grille's and everything else you could need.
See you at the races, Wayne Kerr |
#28 |
Rich , I believe that the Skilmans have those parts in stock.
Holbrook just about has my 352 done for my GT car. I would highly recommend Chris for the top half purchase, he can also help with the fuel injection. This will be my 1st time in a class car, as T/D has been my forte. Skilmans Ford in Greenwood IN, google it. |
#29 |
Liked 18 Times in 6 Posts
Mike at BuyFordRacing might also be able to get you what you need. He's been great to deal with on my project.
I wonder how different the Cobra Jet grill is from the California Special Grill?
2014 Cobra Jet FS/XX #3345 STK/SS Like us on http://www.facebook.com/pages/Daniel...25886327426822 |
#30 | |
Liked 38 Times in 17 Posts
I compared a black 2012 GT/CS grille side by side with my CJ grille recently. Exactly the same except the CJ is cut out everywhere on the backside between the externally visible ribs. The GT/CS grille is closed off in the back for the most part. So you can easily make one from a GT/CS grille. |
