Old 11-06-2012, 01:13 PM   #1
Rich67stang
Liked 116 Times in 27 Posts
Default 2010 Mustang Stocker
Can I run a 2010 mustang with a 352ci rated @ 285hp in stock with a stick?
10.98 x 285hp +170# = 3299# would that put me in C/S
Thanks.
Rich67stang is offline   Reply With Quote
Old 11-06-2012, 01:27 PM   #2
KRatcliff
Liked 531 Times in 143 Posts
Default Re: 2010 Mustang Stocker
Thanks.
10.98 is a natural F/S. You could only drop as low as E/S.
KRatcliff is offline   Reply With Quote
Old 11-06-2012, 01:42 PM   #3
Rich67stang
I knew I would get this all wrong!...lol. So, this combination is legal? how did you come up with F/S? Am I correct with the factor and weight?
Thanks again.
Old 11-06-2012, 02:06 PM   #4
69Cobra
Liked 2 Times in 2 Posts
10.98 = a 10.5# class which is F
So 285x10.5+170= 3,162.5# min. weight for F
then you can move up or down one class so
285x10+170= 3,020# E min. weight
285x11+170= 3,305# G min. weight
Now these are the class minimum weights without nitrous. You have to weight at least the minimum of the next class up with nitrous. So if you were running as an E car with nitrous you would have to weight F's minimum. If you are from the Bayou that rule doesn't count.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 11-06-2012, 02:18 PM   #5
KRatcliff
Thanks again.
Yes, the combo is legal and in the guide. It should fly! You can go to the class weight breaks here. 10.50-10.99 is F/S (or F/SA). You don't do the math to find the natural class since you already had the weight factor of 10.98 listed in the class guide.
http://classracer.com/classes.html
Old 11-06-2012, 02:23 PM   #6
KRatcliff
I forgot your weight question. For F/S you would need a minimum weight of 3,160 lbs. Here's the math.
10.5 x 285 = 2,992.50 You round down to the nearest 5 lb increment, so....
2,990 + 170 = 3,160
Old 11-06-2012, 03:01 PM   #7
SwillRacer
Liked 5 Times in 1 Post
Guys,
I'm new to the world of Stock and Super Stock and I'm now confused. I'm not aware of a 2010 model mustang that came with an engine even close to the 35X cubic inch range and am sitting here wondering how he can run in stock? Especially with a stock crank and stock dimension rods?
did I miss something when I read the rules?
Thanks,
Scott Lovell
SwillRacer is offline   Reply With Quote
Old 11-06-2012, 03:40 PM   #8
69Cobra
Hey Scott,
Welcome to NHRA I know you are or were a NMRA guy for quite awhile. If you click on the NHRA Competition link in the header above and then go to stock car classification guide then go to Ford 2010, Mustang it will give you the NHRA accepted options for that year, make and model. The 352 and the 428 options for this year were paper motors that came in the 2010 Cobra Jets only. These are pushrod motors the 352 is a 302 based engine and the 428 is a 351 based engine. In the same area were you find the stock car classification guide is also the engine blueprint/spec guide. Do the same there Ford, 2010 and it will list part numbers and specs for the engine of your choice. Hope that helps.
Kris Rachford
C/S 3032
Old 11-06-2012, 04:21 PM   #9
SwillRacer
Yep. Thank you Sir, that does help.
But I still feel like I'm missing something. What do you mean by "paper motor"? I'm fairly sure I was unable to buy/order a 2010 mustang with a 428 in it back in 2010. I guess I'm not understanding why that engine is legal in stock if I wasn't able to buy a car like that, special production run or not, from Ford in 2010?
Thanks again for your help. Sorry for the amateur questions.
Scott
Old 11-06-2012, 06:17 PM   #10
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Scott
It's not a requirement that a certain engine be available from the factory in a certain model anymore. Not like the old days.
Confusing, yes.
All Ford did was submit specs for the 352 and 428 to NHRA and they (NHRA) approved an engine combo that only existed on "paper". Hence the paper motor reference. Ford never built those engines.
As posted above:
352 is a 302 block poked and stroked with Z304 Ford Racing heads and a 4 -blade throttle body.
In stock there has to be the correct part numbers on the intake, t.b., heads and of course the pistons and rods have to be to spec. (among other specs listed in the engine blueprint sheet for the 2010 Ford engines)
That engine is built pretty much from the Ford Racing catalog, for the most part.
To the o.p.:
Congrats on having a 2010 CJ Mustang. Have fun with it !
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
