Old 11-08-2012, 09:24 AM   #1
D.Johns
D.Johns's Avatar
Liked 18 Times in 6 Posts
Default Re: 2010 Mustang Stocker
Mike at BuyFordRacing might also be able to get you what you need. He's been great to deal with on my project.
I wonder how different the Cobra Jet grill is from the California Special Grill?
2014 Cobra Jet FS/XX #3345 STK/SS
Like us on http://www.facebook.com/pages/Daniel...25886327426822
D.Johns is offline   Reply With Quote
Old 11-09-2012, 07:03 AM   #2
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
I bought one from them a few months ago. They don't have it listed anymore, maybe I got the last one.
I compared a black 2012 GT/CS grille side by side with my CJ grille recently. Exactly the same except the CJ is cut out everywhere on the backside between the externally visible ribs. The GT/CS grille is closed off in the back for the most part. So you can easily make one from a GT/CS grille.
kdanner is offline   Reply With Quote
Old 11-09-2012, 07:13 PM   #3
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Thanks for posting that info !
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 11-10-2012, 08:35 AM   #4
kdanner
kdanner's Avatar
No prob.
A lot of the special parts for these cars dry up pretty fast. I managed to get some of the mirror deletes recently, but those wouldn't be hard to make either.
Some things I wonder about though. You'd think that based on the rulebook as written, it would be OK to run an 8.8" axle instead of a 9". Based on one of the other threads here, it sounds like maybe that is not the case? Then I wonder about the 12 bolt drop out in a 9" housing, is that not allowed in stock? I'm trying to get everything together to run the NA 5.0 coyote combination, and a 9" axle is just way overkill and has too much parasitic loss.
Old 11-10-2012, 07:12 PM   #5
D.Johns
D.Johns's Avatar
You can run the 8.8 if you want to. The 9-inch has a couple of advantages to it but if your looking at saving some cost your 8.8 will work after you beef it up.
Old 11-10-2012, 11:19 PM   #6
kdanner
kdanner's Avatar
Other than ease of service and more gear ratio selection I can't really think of any. Plus I already have the 8.8 with 9" ends on it and good axles.
Old 11-11-2012, 12:39 PM   #7
ALMACK
ALMACK's Avatar
I find it hard to believe that anyone would get bumped in tech for using a 8.8 in a 2008 + Mustang.
I/PS '95 Mustang GT
Old 12-19-2012, 04:06 PM   #8
Rory McNeil
Liked 1,103 Times in 301 Posts
Are you going to run an automatic or a stick? A 8.8 with an auto should be no issues, but I have a Jerico 4 speed in my M/S 85 Mustang, and I wish I had gone with a 9" instead of the 8.8. The selection of ratios is MUCH better with the 9", a 8.8 offers no ratios between 5.13 and 5.71. Also Pro gears are not available for the 8.8, I have broke 2 sets of 5.13 "street" gears in my 12 second Stocker. Also, in stock form, the 8.8 housing needs the axle tubes welded to the cast center, and tend to bend the tubes. Mine had to be straightened twice , but seems OK since we braced the tubes to the casting.
NHRA 6390 STK
M/S 85 Mustang
