A smoother surface would also tend to reduce friction. This may not be 100% correct you may not want a super fine finish as it may not let your ring & pinion retain the lube the parts don't like to run dry.
Originally Posted by Myron Piatek
Jim's website shows that he can do cryo, the "Finished" surface treatment or both!
I've been getting gears done for a few years and they appear to be lasting longer. I was not in a position to do back-to-back tests with the "Finished" surface treatment, but others I know have had positive responses. It would stand to reason that a highly polished surface would at least have less resistance moving through oil over OEM machined and coated surfaces. A smoother surface would also tend to reduce friction. I wouldn't be wasting my time on it if I didn't think it was beneficial.
