Old 12-09-2009, 06:00 PM   #11
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Default Re: Clutchless tranny in S/S?
Originally Posted by randy wilson View Post
better inform warren johnson, ken blacks bunch, and jegs. they are spending alot of money on nothing when purchasing high priced cutchless units when an m-22 muncie is just as quick. would save them a ton of money. if clutching the car was as quick, everyone not clutching would start doing it to save on break downs. i know it is harder on parts to pull a clutch assisted trans in and out than it is a true clutchless.
Sorry Randy, I should have worded it different. Was told there is no MAJOR advantage...like you said worth a few hundreths, but not much more. You are also correct about the Soft-loc style clutch. I've been running an old fashion rag style non-adjustable, and slips just enough where I can pull the shifter pretty much anywhere. But I know I'm losing at least a tenth as a result.
On a side note I talked to another guy running a GF-2000 who mentioned issues with Gardner Springs popping off. I believe he said it was damaging the sliders as a result. Was a low 9 second small block Mustang weighing approx 2800 lbs. He says it picked up about 2-3 tenths switching from a pro-shifted toploader.
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
