Old 06-10-2022, 08:47 AM   #1
garyc
Liked 51 Times in 30 Posts
Default Vp c-11 pump gas
HI
rumor has it that c11 has a hard time passing fuel check, firing up new build this weekend, every thnig new motor 8.5-1 etc. have fresh c-11, was going to flush new fuel system cell,pump, lines etc with pump gas 93 , would it contaminate cell, foam etc?
garyc is offline   Reply With Quote
Old 06-10-2022, 10:39 AM   #2
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: Vp c-11 pump gas
I use C-11 since 2005, never had a problem with tech.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 06-10-2022, 11:11 AM   #3
Jeff Niceswanger
Liked 1,032 Times in 368 Posts
Originally Posted by garyc View Post
HI
Do not do that. A whiff of regular gas can contaminate the readings. I can't even imagine how screwed up a full load of that regular fuel would do to your chances of passing a fuel check. We have had lawnmower gas in a plastic jug and reused it a week later for race gas and flunked tech immediately.
You will find C-11..."finickly". We ran it for years but every so often, always in super hot muggy conditions it will flunk. You always will know whos running it as on thoses days several of us would be standing around the scales, holding up the lines trying to get 11 to pass. It gets stale easily. Unless you really think your combo likes it (some do), I'd put 12 in it and be done with it ..
Jeff Niceswanger 3740 SS
Old 06-10-2022, 08:27 PM   #4
SDT1DYI
Liked 455 Times in 147 Posts
HI
I would remove the foam in the fuel cell first.
C-11 will be a touch faster than C 12 in your low compression motor.
C 11 Vapor rate is very low , keep in metal cans and in cool places.
Clean out you inline filter and put C11 in it.
You can take fuel to the fuel test pe
trailer before hand and confirm its good if your concerned for any reason.
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 06-13-2022, 02:59 PM   #5
garyc
going to bite the bullet and just use the c-11 $125 5gal pail and flush system, maybe just a gallon or 2, a few dollars will save a lot o grief, might even strain it and put it back in
Old 06-13-2022, 06:51 PM   #6
B Parker
Liked 2,336 Times in 464 Posts
Didn't remove the foam a few years back. What a mistake. Ended up falling apart and into the fuel line. BP
Old 06-13-2022, 08:23 PM   #7
mike britt
Liked 66 Times in 31 Posts
So, it sounds like I need to remove the foam from my cell.
mike britt is offline   Reply With Quote
Old 06-13-2022, 10:19 PM   #8
B Parker
Or leave it in and let us know when not if it ends up in the fuel line. Ended up in my regulator. Though the regulator was bad and replaced it. That one screwed up a run later and that's when I found it. BP
Old 06-15-2022, 08:08 AM   #9
Rsmith38
Liked 28 Times in 15 Posts
The foam will retain the earlier gas and you WILL fail fuel check!!! remove it!
Rsmith38 is offline   Reply With Quote
Old 06-15-2022, 12:42 PM   #10
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
100% agree with removing the foam!! Not even just because you want to test with pump gas, but even if changing race gas brands from time to time. Removing the foam clearly helps fuel check.
Regarding pump gas for tnt, even without foam I got burned one time. I didn’t flush enough race fuel through it (trying to be cheap) and wound up failing fuel and having to waste way more race fuel than if I would have just flushed another gallon or so through.
Kevin Panzino is online now   Reply With Quote
