#11 |
Liked 5,153 Times in 1,967 Posts
Need lower than a 5.13 in that combo , I believe.
#12 |
Liked 275 Times in 76 Posts
A 5.71 is available for the 8.8. Finding the right tire to get the RPM in the traps may be a challenge. The 9" would be a heavy and power robbing way to go. 8.8's may not have optimal gear choices or be soft gears, but they hold up behind a V8 stick car for many years before stress fractures occur.
The adapter plate was used in a stocker mustang with a Jerico and even won class at Indy a few years ago, along with setting a few records along the way. A couple of SVO's were in competition too. I do not know what trans the SVO's were running and may still be competing. One has switched to a different year and auto, the other was a D4 car. If they were running a 5.0 clutch and flywheel the adapter plate is needed for the bigger bellhousing otherwise there isn't an adjustable clutch made for that application. What's the biggest tire that will fit the wagon? Sean
#13 | |
Liked 373 Times in 131 Posts
Sure enough, I did not see anything prohibiting adapter plates. I'll check my 2014 and older rule books, but I thought for sure I saw it printed at one time that transmission adapter plates were prohibited in Stock. At any rate, that's good news.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 08-19-2016 at 04:15 PM. |
#14 | |
Sean
#15 |
He has some 24" tires and we had a 26 x 8" under it on a 7" rim. Might be able to get more if we worked on it a little here and there, but 26" looks really big in that wheel well.
Also I have now found out that you can get a 6.14 in a 8.8" gear. Not sure what else is available from the previous thought limit to the 6.14 or if there is an even deeper ration available yet. Tom |
#16 |
Liked 10 Times in 6 Posts
Sean, 2004 rule book,Under automatic transmission, NHRA-accepted adapter plates permitted.
Tom Moock 5704 STK |
#17 |
Liked 53 Times in 16 Posts
Why wouldn't a Jerico be a viable option? Available in many different gear ratios 1st -4th
Plus what about a Lakewood bellhousing. A heavier flywheel probaly with a adjustable pressure plate. I know Hill's V/S V6 truck runs a combo like this. Will |
#18 | |
Liked 1,443 Times in 302 Posts
The answer is that a Jerico would be a viable option. If you want a bargain, scout for a decent narrow gear DR4. I had one years ago that had had the gears narrowed up a lot! You could do that and still probably not break it.
James Schaechter 3163 STK Last edited by james schaechter; 08-20-2016 at 08:26 AM. |
#19 |
Liked 721 Times in 221 Posts
How in the world would you break a 9 inch with a Pinto motor?The 8.8 would be the logical choice due to size,weight,cost and availability. If 6.14's are available, so would anything else you would need.The 8.8 uses some of the same internal bearings as a 12 bolt.It would definitely be more low friction than the 9 inch.
#20 | |
No doubt a Jerico would be the way to go. A heavy flywheel would not be the way to go, lighter is better. Especially if the engine needs every HP to accelerate the car, and not being used to accelerate the flywheel. This engine has low HP and TQ, so every little detail to be efficient adds up, down to the drag on the brakes. Sean
