#21 | |
Liked 7,664 Times in 1,727 Posts
I can assure you that a 287 CFM 2V will be flowing at least 100% VE. How can I say that? If everything is right in the combo, the engine WILL be pulling vacuum long before it gets to the finish line. OBTW, try explaining that to the man designing your cam.
#22 | |
Liked 49 Times in 15 Posts
Since the wife want's to drive and I've acquired another car......I guess I'll take a stab at it.
Dean Feiock -- Stock 5002 |
#23 | |
Liked 772 Times in 192 Posts
Mopar - 287 max disp, 1.437 B&B carburetor that meters fuel like a straw in the wind, 10.2 compression, .400 lift cam, 176 power rating. Chev 267 - 280 max disp, 1.375 Dual Jet that meters well, 9.5 compression, .357/.373 cam (heads will flow better on the exhaust than the Mopar), lighter reciprocating weight, better transmission (TH200), 150 power rating. Not a cake walk, but very possible. The 273 has been beat on since the '70s, so don't expect to achieve the same level of performance in a month. |
#24 |
Liked 28 Times in 15 Posts
OK got a 267 block and crank but no heads. 513 castings look like one off deal. Will continue the hunt this weekend.
#25 | |
Liked 282 Times in 98 Posts
carb is rated 287,on dyno with air turbine will pull more than 287 cfm. Mike Taylor 3601 |
#26 |
Hey Mike, not for nuthin but a 267 and a 4 speed in your car would be a crapper full of fun!
