#21 |
Liked 2 Times in 2 Posts
Steve, read the posts, i think you'll change your mind. The mans carburetor emptys the float bowl just setting on the work bench,
no vacuum being applied at that time. They should not leak out the idle hole or the transfer slot when not in use. |
#22 |
OK, i fixed it, sort of....
this is what i found, and did. after no success with fixing leak on the car, i took the carb off. i saw that the leak seemed to be coming from the small hole in the left bottom- out to the transfer slots at the butterflies. i painted the main plate surface and took a file to it till i was happy it was straight, drilled out the hole for the metering block pin. put on without a gasket, seemed good, no rock or uneven hitting anywhere. put new gaskets on filled bowl and watched it just drip out of the transfer slots again. ugggh. so i looked at my other quick fuel carb. no hole on this main body. OK, so i taped the hole closed w/ aluminum tape. no more leak, put back on car, no more issues! i would just like to know why this continued to leak and why is it not needed? if it is not needed at all i will prob. go back and epoxy it shut.. thoughts?
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 09-12-2018 at 05:42 PM. |
#23 |
keith, that hole in the venturi hsg. is for holleys timed port vac. system, not in new hsg's such as the 950's. if this application is for a race car "plug" it with some jb weld or a small brass plug, you don't need it. wish i had seen the pic's before as i thought you were using stock metering blocks......good luck.....
#24 | |
#25 |
I have a quick fuel metering block 34-4 on my carb.....Same darn thing has been happening.... I have had the carb apart 6 times trying to figure this out....It leaks out of the passenger side front transfer slot....Floods the motor and ruins the oil.....I was going to try my old metering block today....but maybe I can just plug the hole...
#26 |
yep, i plugged the hole and flipped the gasket just in case. been working great ever since!
#27 |
You can just flip the gasket? I have a few gaskets I'm looking at right now....If I flip one onto the other...three holes are different...I'm gonna go grab a metering block and look at it....I put my stock metering block back on and the leak stopped. Maybe it's in my head but the car doesn't feel as fast....I'm going to the track Saturday.
#28 | |
if you just want to try it out, i put aluminum tape over that hole on the main body first. that is when the leak stopped.
#29 | |
Liked 4 Times in 3 Posts
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
