#11 |
When you guys say the 1.76 gear set, is it a stock used gm gear set with the stock carrier and out put shaft? One option I'm thinking about is a 1.80 straight cut gear by transmission specialties in P.A. The whole tranny is $1600 PL-2500
#12 |
Liked 5 Times in 3 Posts
I would go with the 1.98.... now then in a "stocker" we picked up .15 going from a 1.82 to a 2.08!
#13 |
T-200. I would bet it would drop it to a solid 9.90 over your current set-up. Right now. But what do I know, I'm a stick guy.
Jeff Lee 7494 D/S '70 AMX |
#14 |
Liked 7,685 Times in 1,732 Posts
My Camaro (good 364, 5.13 gear, 10.5 tire, 3350wt) worked and ETd much better with 1.76.
#15 | |
#16 |
I realized that. You didn't drive it on the street that much did you?
Since you have made it race only (correct?), go all out with gearing and weight removal.
#17 |
I drove it enough where it was a pain in the ***. Every friday night to the hang out spot. Still trying to crack the 9's.
#18 |
Thanks for all the replies. I went and bought the Transmission specialties PL2500. 1.80 straight cut gear. I should have it tomorrow. For what it has in it I couldnt pass it up. $1499
$1,499.00 Hello, I am offering one of our unique Proline powerglides with a great price and all of the best options to support up to 1200 HP. The proline 2500 offers a -totally reconditioned stock pump -NEW 300M steel input shaft -NEW 8 Alto Red Eagle clutches/steels -NEW steel lightened clutch hub -NEW 1.80 9310 straight cut gears w/ 2 year warranty -NEW gear housing with 4340 steel output -NEW dual ring billet servo -NEW deep alluminum pan -NEW Pro Lite trans brake -NEW high performance gaskets/seals The PL-2500 is one of our best sellers offering all the KEY internal components. |
#19 |
IMO, you made a great choice. That is an outstanding deal! I think the 1.80 gear is just about ideal for 355-555 inch engines. Bracket stuff, not class cars.
Just remember to stay on top of the band adjustment. I'd check it before every event. Have fun. |
#20 | |
Whats the difference between bracket cars and a class cars? Last edited by L79racer; 12-17-2009 at 02:11 PM. |
