#21 |
there are no differences in the block and such, the only difference is its in a SVO vs a non SVO.
#22 |
#23 |
Liked 70 Times in 29 Posts
The SVO was merely a more European (if you will) looking Mustang. They had 5 lug wheels, bigger brakes, different fascia, heavier sway bars, different steering wheel etc. I believe the engine was the same as the earlier turbo 4 cars. The 20th anniversary 84 GT350 I run was available from Ford with the turbo 4.
(mine was originally a CFI 5.0) My car has some of the same chassis componets as an SVO. I put a ball joint on it 2 months ago and asked for a ball joint for an 84 Mustang GT. It would not fit. I went back and asked for an SVO ball joint and wallah, it fit. SVO's were not coupes, but that doesn't matter if you want to run it in SS/DX. As long as the engine corporate relationship is the same,it makes no difference. You could run a Mercury engine in it if you wanted. Doesn't matter the year or HP. SS/DX is classed by cu inch to weight. You could run that motor in an old Fiesta or a pinto if you wanted as long as the car's weight divided by cu inches was 15.00 or greater. Hellraising racer, I think you need to go to some races and look through the pits at the way stockers/superstockers are built. They are by no means entry level classes. I wouldn't even call IHRA pure stock an entry level class. You would have easily have a couple thousand dollars in a T-5 transmission by the time you bought a rebuild kit, a shifter, straight cut gears, and good clutch set up. You may even want to go to a Fun Ford Weekend to look at those various cars as well. Some meets have SVO clubs there meeting there as well.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#24 |
I cant run it as a SVO because of the hatch notch problem, BUT i did do some digging and calling, 1979-83 coupes did come with a non intercooled turbo motor that i can run in stock class and super stock, i just have to change my front end and tail lights.
#25 | |
Liked 1,583 Times in 582 Posts
http://classracer.com/classforum/showthread.php?t=10722 |
#26 |
Liked 31 Times in 10 Posts
I suggest you build an 80 turbo mustang and race it in u-v/s or /sa. Your superstock idea is not a great one. I believe the record holder (in u-v stock) stated that he can run around 2 seconds under the index. Read the rule book a few more times and you'll understand the questions you have a little more.
#27 |
I don't know about anyone else, but I am confused as to exactly what you want to build.
You are talking about so many different combinations that they have all run together.
#28 |
Liked 971 Times in 308 Posts
Hey Chris1529, the SVO Mustang 84-86 has a built in lower ball joint from the factory. I know I've taken one apart and they are not replaceable. Going to have to machine it out and put in a repaceable one from a different vehicle.
#29 |
I thought my ball joints were that way too according to the shop manual, but it pressed out.
I had to ask for an SVO ball joint at Advance Auto. It was about 3/16" larger than one for a regular GT.
#30 | |
Liked 5,121 Times in 1,952 Posts
(specifically, a white one!) He needs to make his an 83 and run P or Q/Stock. He could convert it to SS later ,if he hadn't spent enough money yet.
