Old 10-23-2014, 01:35 PM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Fox and SN95 Mustang rear control arms
Originally Posted by Chris1529 View Post
I have UPR upper and lower on my car. None are adjustable.
Eibach drag springs, no sway bar.
What size slick you running Chris? Got a side pic of the car?
Rich Taylor
I/SA - 321
Old 10-23-2014, 01:52 PM   #12
Dave Gantz
Liked 251 Times in 125 Posts
Originally Posted by HandOverFist View Post
How about a set of adjustable lowers once set then welded up solid? No longer adjustable, right? I'm always digging... I've noticed that most of the aftermarket lowers are still using poly bushings instead of solids.
I think the idea is, that they don't want you messing with the wheelbase. If all 4 are adjustable, how does the tech guy know what you've done? He could measure the wheelbase, yes, but you may have moved the front wheels to compensate for the rear change.
I'll bet no one ever moved their wheelbase around...
Old 10-23-2014, 02:01 PM   #13
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Here is a copy-n-paste from the 2014 NHRA rulebook:
SUSPENSION, Rear
Must remain as produced, except for the following: Leaves may be
changed (added or subtracted) as long as overall length and
mounting points are used. Coils may be changed (clamped or
spaced) as long as stock mounting points are maintained. Solid
bushings in rear suspension permitted. Cars with rear coil springs
may relocate the upper control arm at rear-end attachment point.
Rear trailing arms may be replaced with NHRA-accepted OEM-type
aftermarket units. Aftermarket lower unit must be non-adjustable
and have bushed ends (no heims). Aftermarket upper unit may be
adjustable and use heim ends instead of bushings. Sway bar(s)
optional. OEM or aftermarket torque arm permitted only on vehicles
OEM-equipped with a torque arm. OEM torque-arm attachment
points at rear end must be retained. See General Regulations 3:4.
As Charlie stated above, if a racer showed up with lowers that have an adjustable spring height , a tech guy might take it all wrong and ...
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-23-2014, 02:48 PM   #14
HandOverFist
My guess is then any lower control arm with solid bushings will do...the cheaper the better. On the hunt for the cheaper now...
Rich Taylor
I/SA - 321
Old 10-23-2014, 03:23 PM   #15
west coast
Liked 223 Times in 73 Posts
Here is my take on this subject. For rear suspension double adjustable uppers everybody makes them, both upper and lower needs to have spherical in all joints, this will make your rear suspension very free when this happens you will need to do some thing like a sway bar or others use air bags to help this. Finding lower arms with spherical bearing in both ends is rare I think BMR makes some.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 10-23-2014, 03:27 PM   #16
HandOverFist
Pricey, but very nice... http://www.cjponyparts.com/bmr-rear-...-1998/p/LCA39/
Rich Taylor
I/SA - 321
Old 10-23-2014, 03:39 PM   #17
HandOverFist
SUSPENSION, Rear
Are the old Southside Machine bars considered legal? I don't see where any of these suspension parts are NHRA accepted in writing.
Rich Taylor
I/SA - 321
Old 10-23-2014, 05:29 PM   #18
ALMACK
ALMACK's Avatar
I see no reason why they would not be legal.
Those arms are not adjustable.
I/PS '95 Mustang GT
Old 10-23-2014, 09:28 PM   #19
7423
I would love to spherical bearing on the lowers, but once again, if you get a tech guy with a stiffy, you will wish you had bushings and a grease gun.
7423 is offline   Reply With Quote
Old 10-23-2014, 10:50 PM   #20
Liked 5,121 Times in 1,952 Posts
A couple of rings of soft rubber on the outside and ..ah never mind...I didn't say it.
