Old 10-22-2014, 09:30 PM   #1
7423
Default Fox and SN95 Mustang rear control arms
Time to upgrade my tired and worn out off shore uppers and lowers. Looking at UPR Products chrome moly extreme series adjustable uppers and fixed bushed lowers. What do you have?? What do you like and what do you hate? Factory OE rear sway bar?
Thanks in advance..........
7423 is offline   Reply With Quote
Old 10-23-2014, 01:52 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Fox and SN95 Mustang rear control arms
As I'm just starting a O/SA build I would like to hear about these things as well since I have zero experience with the Fords Charlie.
I've been eyeballing the Maximum Motorsports adjustable lowers...thinking it might be handy to be able set ride height with the springs. I really have no clue as to whether it would be beneficial tho...I have not even decided between 26" or 28" tires. Does a rear sway bar make much difference in these Mustangs at these power levels?
I was thinking any adjustable upper control arm would be fine, but again I am just guessing at this point. You use these to set pinion angle, right?
Rich Taylor
I/SA - 321
Old 10-23-2014, 09:38 AM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Lower control arms cannot be adjustable. Global West makes a nice lower, and the uppers can be adjustable, Team Z, Wild Rides, and UPR have nice ones.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 10-23-2014, 09:49 AM   #4
Ron Middleton
Liked 12 Times in 4 Posts
We've used the UPR ones on so many different class Mustangs with great results. I'm currently gathering parts for my Fox body stocker and it will wear UPR rear suspension components.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 10-23-2014, 09:56 AM   #5
HandOverFist
By adjustable I meant the spring perches, not in length. Would these be legal? Are you guys using a sway bar on the rear?
Rich Taylor
I/SA - 321
Old 10-23-2014, 10:28 AM   #6
rick978
rick978's Avatar
we are usin adj uppers but lakewood traction action lowers . so far works great
rick978 is offline   Reply With Quote
Old 10-23-2014, 11:41 AM   #7
futura302
For my street/strip Fairmont we used Kenny Brown Performance lowers and adjustable uppers, which work great.
For the Mustang stocker we're using the old Southside Machine lowers (mounted in the stock location) and double adjustable uppers. Looking into a couple of different options to relocate the upper control arm mounting point at the rear end housing to improve the instant center.
Aaron Puff
AWARENESS MOTORSPORTS
1985 Mustang Crate Motor Stocker
futura302 is offline   Reply With Quote
Old 10-23-2014, 12:18 PM   #8
7423
Probably not a good idea. Visions of a very narrow minded tech inspector in a bad mood signing your card in red ink instead of black. The rulebook does use the term non adjustable. The jury is out on the factory sway. Not real sure if it is of any value. I have always used the factory bar and have no experience without one.
Old 10-23-2014, 12:40 PM   #9
HandOverFist
How about a set of adjustable lowers once set then welded up solid? No longer adjustable, right? I'm always digging... I've noticed that most of the aftermarket lowers are still using poly bushings instead of solids.
Rich Taylor
I/SA - 321
Old 10-23-2014, 01:33 PM   #10
Chris1529
Liked 70 Times in 29 Posts
I have UPR upper and lower on my car. None are adjustable.
Eibach drag springs, no sway bar.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
